TierHive | 128MB Ram - 1 GB Disk = $6 for 5 Years! (yes actually) | Hourly VPS | FREE to try.
AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
Go here and play with the sliders, build your own package: TierHive
vCPU: 1vCPU for upto 2048MB then anything over gets 2vCPU
Ram: 128MB upto 4096MB - 128mb incrememnts
Disk (NVMe): 1GB upto 50GB - 1GB Increments
Disk (HDD): 1GB upto 4000GB - 1GB increments
Disk (Network): 1GB upto 100GB - 1GB Increments
Free HAProxy, Load balancing, Failover, SSL, SQL Offload, Email relay
Actual hourly billing with 1 hour minimum
Meshed NAT, each user gets a /24 from 10.0.0.0/8 you can use your /24 over all locations and all your VPS can talk to each other over the mesh no matter the location.
For the rest of February, the minimum top-up is $3 instead of $5, credit never expires, services auto stop when you run out, you have around 3 days to recover, after that they are deleted, we auto cancel debt, so you will never owe anything.
We are privacy-focused, we don't want your ID or personal details, the free trial credit does not require a credit card or validation, its enough to get you running for a few hours or a few days or weeks, depending on what you deploy.
Locations:
  • Canada East
  • Kansas, MO, USA
  • London, UK
  • Frankfurt, DE
You can self-migrate your own server in most instances. Big HDD storage is only available in London right now, working on S3 compatibility before we also roll out big storage in the USA.
Cheers!
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
Thanked by (3)jcn50 imok nick_
  • I need classic Openvz 6 to make my kernel run with 128 MB. :p
  • AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
    We have Alpine and freedos you will be fine!
  • teamaccteamacc OGSenpai
    Would you consider significantly increasing sql offload size (30-50gb) or is that way beyond the scope of this project?
  • edited February 21
    CPU (vCores): 1 vCPU
    CPU Priority: High Priority
    RAM: 1024 MB
    Fast Disk (NVMe): 11 GB
    IOPS Tier: High Performance
    Network Tier: High Performance
    VPS Resources: 0.001232 tokens/hr
    Total Hourly Cost: 0.001232 tokens/hr
    Monthly Estimate: ~0.8991 tokens
    Interesting little setup. cpu steal was pretty reasonable even as yabs was running - 3% ish, but iowait spiked to around 50%
    Will be interesting to see how it does under normal use tho! :)
    Fri Feb 20 23:49:38 CST 2026
    Uptime     : 0 days, 0 hours, 11 minutes
    Processor  : AMD EPYC 7B13 64-Core Processor
    CPU cores  : 1 @ 2250.000 MHz
    RAM        : 967.9 MiB
    Swap       : 1.0 GiB
    Disk       : 10.7 GiB
    Distro     : Debian GNU/Linux 13 (trixie)
    Kernel     : 6.12.73+deb13-cloud-amd64
    ISP        : Fro LLC
    ASN        : AS22295 Advin Services LLC
    Country    : United States
    Read       | 986.00 KB/s    (246) | 15.78 MB/s     (246)
    Write      | 1.01 MB/s      (254) | 16.29 MB/s     (254)
    Total      | 2.00 MB/s      (500) | 32.07 MB/s     (500)
    Read       | 125.42 MB/s    (244) | 250.78 MB/s    (244)
    Write      | 132.08 MB/s    (257) | 267.48 MB/s    (261)
    Total      | 257.50 MB/s    (501) | 518.26 MB/s    (505)
    Clouvider       | London, UK (10G)          | 248 Mbits/sec   | 197 Mbits/sec   | 97.3 ms
    Eranium         | Amsterdam, NL (100G)      | 179 Mbits/sec   | 161 Mbits/sec   | 101 ms
    Uztelecom       | Tashkent, UZ (10G)        | 78.3 Mbits/sec  | 82.9 Mbits/sec  | 245 ms
    Leaseweb        | Singapore, SG (10G)       | 130 Mbits/sec   | 66.8 Mbits/sec  | --
    Clouvider       | Los Angeles, CA, US (10G) | 228 Mbits/sec   | 208 Mbits/sec   | 41.2 ms
    Leaseweb        | NYC, NY, US (10G)         | 263 Mbits/sec   | 201 Mbits/sec   | 30.1 ms
    Edgoo           | Sao Paulo, BR (1G)        | 136 Mbits/sec   | 174 Mbits/sec   | 188 ms
    Single Core     | 891
    Multi Core      | 516
    Full Test       | https://browser.geekbench.com/v6/cpu/16680259
    YABS completed in 40 min 25 sec
    I think it's likely to move to a charge based on space and activities in the long run without a specific limit, but for now to be honest I am being held back from cutting it completely.
    So few people are using it compared to the overall customer base, but still not even out of month 3 yet I keep getting reminded.
    So it needs a rethink, redesign, revamp or just more time, it's not worth the maintenance overhead. But you know that's what an ALPHA is for, testing and learning what you need to fix.
    Do you actually have a database that size you need hosting for that you would be happy to have on none critical infrastructure? I might be able to help you out with it as long as expectations are realistic.
    RAM: 1024 MB
    RAM        : 967.9 MiB
    Swap       : 1.0 GiB
    Disk       : 10.7 GiB
    ISP        : Fro LLC
    Single Core     | 891
    Multi Core      | 516
    Haha yeah iowait would always spike as you are being artificially limited after your initial burst.
    That's the sign of a very curious or very patient person to run yabs on TierHive haha.
  • @AnthonySmith said: Meshed NAT, each user gets a /24 from 10.0.0.0/8
    But no IPv6?
    But no IPv6?
    Not yet, we will have Ipv6 in when we get to Beta.
    We want to make sure it's done in a platform appropriate way.
    Thanked by (3)cmeerw yoursunny jureve
    So no suspension on CPU and I/O at 100% all the time, just throttling?
    Thanked by (1)jcn50
    @yoursunny said: So no suspension on CPU and I/O at 100% all the time, just throttling?
    Basically, yes, but your priority will just get lower and lower and lower IF doing this causes contention for other users on the same or a higher tier as you.
    Thanked by (2)jcn50 yoursunny
  • I am from Vietnam and get this message:
    Kernel Keepers
    403
    At this time we are unable to provide services in your location
  • In the other thread you say:
    All Linux/BSD templates available
    But, NetBSD is missing... Any chance/interest in adding that?
    Oh dear, you are right it is set to admin only on our side, I will ask my colleague why he did that, I assume it's a good reason.
    You can boot to rescue and use netbook.xyz to install it in the meantime time if that helps or pick no os and chain load it via ipxe.
    We had the template live, I will find out why it's not and when it will be back on Monday.
    Sorry about that.
