Well I remember paying over $1000 for a 1TB NVMe not THAT long ago, market pressure is set to go way higher than it was when 1TB was a big NVMe so.... Interesting times ahead.
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith FREE tokens when you sign up, try before you buy. | Join us on Reddit
I have played with 2x 24 SSD ( 128 to 256 GB ) in DELL MD1220 + Optane or NVME as chache, 256 GB RAM, high freq CPU and whatever you can imagine you can tweak in zfs. Used Debian, Ubuntu, Freenas, TrueNAS Core/Scale.
same for 12 or 24HDD in DELL MD1200.
Sincerely, total waste of time.
The second you hit it with random HIGH IO from VM's over 2x10GBPS or 2x25GBPS it will utterly suck.
Storage exported via ISCSI was much faster then NFS, but I did not fall of my chair performance wise.
Other the the ability to extend a pool on the fly by replacing drives with larger ones and the strong data integrity ZFS gives you, I personally see no real value in it for our use case.
/2c after burning far too many hours in tests.
I spent about 4 weeks tuning and exporting storage over 40g from truenas using iscsi and the performance in proxmox was always abysmal, switched to nfs export and got 7gbps throughput (up from 1.3) and a 5x increase in available iops.
You do seem better equipped than me on hardware and I don't doubt that you're in a better position to test this, but I think you may have missed the plot here
Point of my post was that throughput doesn't measure real experience. So if you hit me with "The second you hit it with random HIGH IO" then I think you didn't read my post
@ZizzyDizzyMC said: I spent about 4 weeks tuning and exporting storage over 40g from truenas using iscsi and the performance in proxmox was always abysmal, switched to nfs export and got 7gbps throughput (up from 1.3) and a 5x increase in available iops.
Any idea what I did wrong?
ISCSI writes by default are synchronous/SYNC, you most probably mounted NFS ASYNC, hence the 3-7X difference, that slow performance over ISCSI is the real performance of your raid array sincerely ( I presume 4 disks? ) , ASYNC is RAM CACHED, SYNC is flushed to the disk in real time + ACK that it got written back to the node - much much slower yet much much safer integrity wise in case a power outage / kernel stalls on both ends.
iSCSI (sync) = disk performance - the hard core truth
NFS (async) = RAM performance - the nice multi GBPS you wish to see, but it is a lye
NFS can also be SYNC, in that case it will behave lice ISCSI SYNC, yet most use it ASYNC.
Also, Promxox ISCSI implementation is a bit ...... not the best in my view compared to vMware or Microsoft ( no offense folks, it is the truth )
Atention!!!!!!!!!!!! Proxmox does NOT have a clustered filesystem like VMFS5/6. iSCSI is block access, like physically having those disks in the server you mounted them on. ( well not disks, exported LUN ) It is NOT file-system-aware!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you mount the same LUN on 2 servers, bingo, they will write data on each-other's blocks. There are work-arrounds like GFS2 yet, it hardly worth the effort.
I would personally avoid NFS for VM storage as well!!!!!
Why:
Proxmox mounts NFS persistent, if the NFS share becomes unavailable (NAS reboot, switch reload, VLAN issue, usual stuff that can happen), the mount can enter D state. - you are fuked, and this is a node reboot fix only as the kernel will wait indefinitely.
Over time, the node may start misbehaving (hung tasks, blocked I/O, GUI lag, usual shit-show )
Yes, that persistence is part of NFS consistency model and that is a very good thing, but operationally it can be painful, and once you start hitting it a few times and your cluster crashes because the ISO repository is not accessible anymore, you will wipe it out completely from your config, we did.
ISCSI was designed for shared storage to phisical server, that is why you even have ISCSI built in the lan card on servers so you can boot the OS from ISCSI while having 0 drives in the server
Also, I will be an ass, but........
Depending on the config:
NFS outperforms iSCSI
iSCSI outperforms NFS
Both perform terribly in my view as are a bit tricky to maintain.
If you want simplicity -> local RAID still wins in latency.
Small note:
Fibre Channel was purpose-built for SAN delivered the most stable and ow latency shared storage - and I loved it as it truly was a set up and forget setup.
Sorry for that, I did miss by a mile, and that was not my point. I thought you encountered the same issues as we did, expecting wow, while getting mehhhhh.
@havoc
Why:
Small note:
@havoc
