microLXC Public Test
1181920212224»
    @Neoon said:
    PK is back online, I am sorry for the downtime, but it took 14 days+ for a ticket response.
    Wow, that was fast! Usually it should take 1 to 2 months...
    Comparing it to Virmach, its actually fast.
    Thanked by (2)ElonBezos jcn50
    NZ connectivity issues on IPv4 should be solved too.
    Ticket took a bit to find the cause.
    Thanked by (1)jcn50
    Just a short PSA, I was busy.
    Yes PK is down, and yes its down since yesterday.
    Ticket is open since yesterday, they are still working on a resolution.
    Thanked by (1)jcn50
    They are away to celibate CNY (cause right after that, month of Ramadan starts) :lol:
  • Unfortunately, I do not meet these requirements.
  • @Neoon can help to check on the alpine config when you are free?
    Running free -h reports the host's memory in alpine, not the guest alpine OS, while cat /sys/fs/cgroup/memory.max shows the memory correctly. Probably some config issue or some weirdness with Alpine itself...
    lxc5d7a7b88:~# free -h
                  total        used        free      shared  buff/cache   available
    Mem:           7.7G        5.8G      535.7M      361.3M        1.4G      246.5M
    Swap:             0           0           0
    lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.max
    268435456
    lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.current
    27455488
