TierHive | 1.5 GB Ram + 15 GB Disk = $15 p/year | Hourly VPS | Build your own plan | FREE to try.
AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
Go here and play with the sliders, build your own package: TierHive
Example plan $1.25 p/month equivalent ($0.001381 per hour)
vCPU: 1
RAM: 1.5 GB
NVMe: 15 GB
Free: SQL Offloading
Free: Round Robin or Failover or Sticky Routing load balancer.
Free: SSL Termination.
Free: Email Relay Service.
Free: Scripted deployment Library, store your own or use public ones.
Link: https://tierhive.com/#calculator
Not going to be using it for a while? take a backup, delete it, stop paying immediately, only a 1-hour minimum is required.
Pricing:
vCPU: 1vCPU for upto 2048MB then anything over gets 2vCPU
Ram: 128MB upto 4096MB - 128mb incrememnts
Disk (NVMe): 1GB upto 50GB - 1GB Increments
Disk (HDD): 1GB upto 4000GB - 1GB increments
Disk (Network): 1GB upto 100GB - 1GB Increments
Free HAProxy, Load balancing, Failover, SSL, SQL Offload, Email relay
Actual hourly billing with 1 hour minimum
Meshed NAT, each user gets a /24 from 10.0.0.0/8 you can use your /24 over all locations and all your VPS can talk to each other over the mesh no matter the location.
For the rest of February, the minimum top-up is $3 instead of $5, credit never expires, services auto stop when you run out, you have around 3 days to recover, after that they are deleted, we auto cancel debt, so you will never owe anything.
We are privacy-focused, we don't want your ID or personal details, the free trial credit does not require a credit card or validation, its enough to get you running for a few hours or a few days or weeks, depending on what you deploy.
Locations:
  • Canada East
  • Kansas, MO, USA
  • London, UK
  • Frankfurt, DE
You can self-migrate your own server in most instances. Big HDD storage is only available in London right now, working on S3 compatibility before we also roll out big storage in the USA.
Cheers!
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
    What happens to 90-day inactive accounts with no running service but non-zero credits?
  • AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
    They remain active.
  • I really want to try cramming my legacy shit in lower use service, but I've become complacent since moving everything to KVMs a decade ago. I know it's plausible to run IPv6 and proxying through for various services (http/https), but I still haven't figured out how to handle nameservice translation for IPv4.
  • It would be convenient if there is a looking glass page for testing network routes.
    Thanked by (1)sh97
    Ok I will add it to the list
    Thanked by (1)lgsin
  • teamaccteamacc OGSenpai
    I don't think your slogan makes sense on here "Don't idle and waste your money" is the exact opposite of what we do here, all day, every day.
  • somiksomik OG
    edited 12:54AM
    Exactly! We are dedicated to our cause of idling. I got myself 5 dedicated servers (2 of which are at my home), just so I can idle my VMs with dedicated resources. :lol:
    @AnthonySmith I see that the sliders go down to 1GB for disk. Is that enough for OS? If it's a KVM VPS, I would assume it needs more storage then 1GB... (Is it KVM or LXC?) Shouldn't you make it so it has the bare minimum for OS at the very least?
    edited 3:52AM
    @somik said: the bare minimum for OS at the very least?
    If I understand right, all the following distros are mentioned as fitting in 1 GB of disk at 5 tiny Linux distros to try before you die:
    Maybe any of them or Alpine or NetBSD could be installed in 1 GB of disk at Tierhive?
  • somiksomik OG
    edited 4:24AM
    Well, I am running a alpine linux on MicroLXC which is using 135 MB of disk, 24 MB of RAM. So I guess it would work for that, but I thought the linux kernel is getting bigger and bigger so would consume more if you are using a KVM instead of a shared kernel container like LXC...
  • usr123usr123 OG
    edited 5:37AM
    So does each VPS receive an IPv6 address too?
    Not yet, but is on the roadmap.
    src: previous posts
    Alpine and Debian bare bones will fit, backtogeek.com is on Alpine and on the smallest possible plan for example, about 700mb free.
    Also some people are running from ram.
    That's to name a few examples there are many more :)
    Well, I am running a entire OS + webserver + db from RAM. I mean if you got 64 GB of ram in your server, you want to test it's limits :lol:
    Anyone who wants to try this out, remember, running everything from RAM is all good if it's readonly. When you try to write, you need to write back to the disk and that's where the problems arises... Also, bootup is longer thæn HDDs as everything needs to be copied from SSD to RAM.
    There are plenty of tiny kernels that will boot and run in <128mb ram that requires no persistent storage with almost unlimited use cases.
