Cheapest set-it-and-forget-it storage
What is the cheapest set-it-and-forget-it storage for photographs that I will rarely need to access? Need about 250 GB of space. With a provider that's been around and won't need to think if they'll disappear in the next ten years.
Please quote pricing.
  • Thanked by (1)sh97
    @host_c obviously, has been solid so far.
    I still dislike the routing, he drops everything off in Frankfurt, with only a few exceptions.
    Prices increases are a concern though, already 100% on some special packages.
    However from the availability and support its good.
    Thanked by (1)Wonder_Woman
  • Google drive or AWS bucket? That's the best reliable storage I know of...
    Yeah Amazon glacier was my first thought too
    Pricey though if you ever need to access it
  • Hetzner storage box maybe; overkill in terms of space, but cheap and admin-free
    With the way the market is, that's very variable right now. I know I didn't think costs would increase by 500% for me, then they did.
    Probably some megacorp for 250GB - Amazon, Google, Cloudflare, Backblaze
    Honorable mentions: Digital Ocean, Hetzner, OVH, AliCloud
    I personally think any host that has a large segment of the low end market will end up in a very hard spot in the coming year or two unless something drastically changes in the market. Host_c is probably one of the only hosts on this forum I think is prepared to weather the storm - albeit from already owning hardware and cannibalizing servers for what's needed to cover failures. I was going to do that but I only owned 4 nodes.
  • Ultravps.eu
    Solid uptime and decent network
  • edited 6:16PM
    If I were you I'd go with the Koofr lifetime plan while it's still around. Company is quite stable and has been around for ages.
    Although I just realized this may not quite be "set it and forget it" as the lifetime plans will at some point clear the data if you never log in.
  • How does Backblaze compare to AWS and/or iDrive?
  • +1 for koofr, i use it exactly for this, Rock solid.
  • I happily use Host-C, Koofr, and Backblaze for different long-term storage things and all have worked well!
