Main Server IP: Offline
Node Server: Offline
While you wait for a support agent, here's a suggested solution.
AI
Your server and node are currently offline. We recommend starting with a server reboot, which often resolves temporary issues. If this does not help, a network reconfiguration might be necessary. Additionally, please log in to your VPS control panel to check server status or review any recent changes. If the problem continues, it might require further investigation by a network specialist.
This is an AI response. It may not always be correct. If it resolves your issues, please close the ticket.
Please wait for a staff reply. If you need to add more information, you may have to close this ticket and start over. Otherwise we have already received your previous message and have already flagged your ticket to the correct department for a response. Further replies at this point would only delay resolution.
It's been almost half a year.
Don't tell me about these offline services. Are they all going to be migrated to Japan in the end?
@JoeMerit said: @edenten if you had a San Jose server, he apparently took them all to Los Angeles and he needs to assign new IPs to them so that they'll work.
Almost half a year has passed. Got across by swimming?
They are on the top of a turtle at the moment, slowly swimming to Japan! Most of the time the turtle is underwater so Starlink can't connect (don't you dare say that VirCrap is at fault here!).
Don't you like the hope story???... Remember: VirCrap didn't deadpool! Just buy more services across different locations to shuffle your uptime (=offline) probability, so that you can join the supporters' bucket!
Do we have a group photo with @vortexnode?
AI
Don't forget to renew!
💩 VirCrap 💩
Just renewed my storage server for another 3 months.
I hope it does not die.
It has been performing incredibly well despite being HDD.
No. I know Chris Miller, but I've not met the other two.
QuickPacket - Dedicated Servers in Ashburn, Los Angeles, Chicago
has anyones SJC VPS been online at LA?
1.5L of chemical flan is ready. Excuse the mess, some glass containers went missing.
A bunch of different spec VPSes gathered together on flan-css style monitoring page!
I found this video of flan being prepared for @imok :
https://www.reddit.com/r/oddlysatisfying/comments/1riw0do/a_giant_perfect_flan/
Oh that looks very tasty!
