1427428429430431433»
  • Do we have a group photo with @vortexnode?
  • Main Server IP: Offline
    Node Server: Offline
    While you wait for a support agent, here's a suggested solution.
    AI
    Your server and node are currently offline. We recommend starting with a server reboot, which often resolves temporary issues. If this does not help, a network reconfiguration might be necessary. Additionally, please log in to your VPS control panel to check server status or review any recent changes. If the problem continues, it might require further investigation by a network specialist.
    This is an AI response. It may not always be correct. If it resolves your issues, please close the ticket.
    Please wait for a staff reply. If you need to add more information, you may have to close this ticket and start over. Otherwise we have already received your previous message and have already flagged your ticket to the correct department for a response. Further replies at this point would only delay resolution.
    It's been almost half a year.
    Don't tell me about these offline services. Are they all going to be migrated to Japan in the end?
  • @edenten if you had a San Jose server, he apparently took them all to Los Angeles and he needs to assign new IPs to them so that they'll work.
    Thanked by (1)bmoto
    Almost half a year has passed. Got across by swimming?
  • @edenten said: It's been almost half a year.
    Don't forget to renew!
    They are on the top of a turtle at the moment, slowly swimming to Japan! Most of the time the turtle is underwater so Starlink can't connect (don't you dare say that VirCrap is at fault here!).
    Don't you like the hope story???... Remember: VirCrap didn't deadpool! Just buy more services across different locations to shuffle your uptime (=offline) probability, so that you can join the supporters' bucket!
    💩 VirCrap 💩
  • imokimok OG
    edited February 28
    Just renewed my storage server for another 3 months.
    I hope it does not die.
    It has been performing incredibly well despite being HDD.
  • qpsqps Hosting ProviderOG
    @imok said: Left is @seriesn? Right is Chris Miller? Center is @qps?
    No. I know Chris Miller, but I've not met the other two.
    Thanked by (1)imok
    QuickPacket - Dedicated Servers in Ashburn, Los Angeles, Chicago
  • 1.5L of chemical flan is ready. Excuse the mess, some glass containers went missing.
    Thanked by (1)ZA_capetown
    A bunch of different spec VPSes gathered together on flan-css style monitoring page! :)
  • Oh that looks very tasty!
    Thanked by (1)Wonder_Woman
    Isn't flan just egg pudding? How many eggs went into that batch?
