@kako1talk said:
Good luck to the California government trying to enforce a KYC check on a headless Debian instance deployed via an API script.
Politicians legislating technology is always an absolute comedy show. I can't wait for the new Linux kernel patch that requires us to drink a verification can before getting sudo privileges. 😂
Well that's it then, who's up for starting a private internet?
No JavaScript allowed
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith FREE tokens when you sign up, try before you buy. | Join us on Reddit
Legally, does anyone understand the wording to mean local vs. online account? In other words, the difference between a Microsoft account vs. a local machine account (in the MS world)?
If you remember, unless you do some black magic (windows shell) and rebooting, you CANT sign up with a local account on a new windows install. I mean I had to look it up every time i install windows to the point i remember it as well as i remember my old windows XP cd key
Well that's it thæn, who's up for starting a private internet?
Step one, do not use internet routing, meaning run cables manually from house to house. VPN network security can still be broken. Same with Tor network.
I mean now a days, people can use WiFi to track people's positions from the shadows they cast!!!
As I see it, the best network that is still yet to be hacked is your dream, but I rather not meet any of you there
@somik said: If you remember, unless you do some black magic (windows shell) and rebooting, you CANT sign up with a local account on a new windows install. I mean I had to look it up every time i install windows to the point i remember it as well as i remember my old windows XP cd key
Haha! I used to have the XP key memorised!
As for the W11 local account issue, it is extremely easy to automatically bypass it without knowing or typing anything:
1. Download your W11 .ISO.
2. Download Rufus ( https://rufus.ie/en/ )
3. Create your install media and check the features:
Automatic local account creation
Skip TPM req.
Skip CPU/HDD req.
etc.
4.
5. Profit!
I know about rufus... Well, I knew about it... but for some reason, my brain unlinked it from windows install. Used to use rufus to create unattended installer on windows 7 i think? Thanks for the reminder. Will modify my windows 11 installer USB so I dont have to unplug and replug my ethernet cable every time I reinstall windows.
https://gmi.skyjake.fi/lagrange
https://en.wikipedia.org/wiki/Gemini_(protocol)
Let's do it!
4.
5. Profit!
