Full-fledged registrar with full DNS hosting + auto DNSSEC + EU + cheap?
edited March 4 in Requests
Currently considering transferring out a couple of domains... but where to? Knowledgeable hints welcome, as I've some pretty tight holes, hmmm, requirements.
These are:
  • (must) support .tel and .net
  • (must) host all types of dns records (not just the meager A/MX/TXT stuff)
  • (must) automate DNSSEC signing
  • (nice to have) based in the EU, not US
  • (nice to have) inexpensive 'cause I'm Mr Cheapo
Already inquired/experienced, but rejected:
SpaceShit, Namesilly-o, Name.Cum, SUV, Porkburp, 0VH...
  • Might we well just start your own.
  • You give no reasons why you won't consider the registrars you named.
  • FalzoFalzo Senpai
    InternetX
  • edited March 4
    Because they fail at one or more of the requirements, obviously. For instance SpaceShip does autoDNSSEC but supports very few record types. OVH supports autoDNSSEC and all record types... but not for the .tel tld. And so on.
    @Falzo said:
    InternetX
    Thanks. Can't locate their Price list/Preisliste, I thought it was mandatory nowadays :o
  • TheDPTheDP OGSenpai
    Checked out Netim and INWX?
    Thanked by (1)Shot²
  • edited March 4
    Netim looks promising, thanks ^^ Not cheap but has all the features.
  • Have you considered splitting registrars and DNS hosting? That would probably give you more options for your requirements of record types and automated DNSSEC.
    Thanked by (1)Shot²
    I looked into this, thanks. Unfortunately the extra cost of a separate DNS host (whose free plans are unsuitable/too limited) makes it more expensive than some registrars :# I'll go with Netim I guess, as suggested by TheDP :)
    You probably didn't look hard enough. See desec.io
    They support all rrset of powerdns so every niche record types are available, and dnssec by default. Only cons are lowest ttl 1h so no short 60s ttl like others. I think new account are limited to 1 zone only now but simply emailing them asking to raise it they'll raise limit to 15 zone.
    Thanked by (1)Shot²
  • WSSWSS OG
    edited March 5
    @Shot² said: I looked into this, thanks. Unfortunately the extra cost of a separate DNS host (whose free plans are unsuitable/too limited) makes it more expensive than some registrars I'll go with Netim I guess, as suggested by TheDP
    You've already shit on Porkbun, but they, Hurricane, and a billion others are happy to host NS for you (even without using them for registration).
    I just do my own because it costs me like $12/yr for stable hosting.
  • noackhostingnoackhosting Hosting Provider
    if its not to late. We do offer registrations and such for over 600 TLDs and do run anycast-dns network with 24 dns servers and offer premium with 100% sla uptime. First option cheap. I dont know if i can put links but I just do a short one then here
    Mikael Krantz
    email: [email protected] [email protected] [email protected] No Ack Infrastruktur AB aka No Ack Hosting
  • @noackhosting said: if its not to late. We do offer registrations and such for over 600 TLDs and do run anycast-dns network with 24 dns servers and offer premium with 100% sla uptime. First option cheap. I dont know if i can put links but I just do a short one then here
    I think may be cool if you will offer trustee service (like njala or incognet) when my domain registered to No Ack Infrastruktur AB.
    At least it sounds cool. B)
    we offer anything.
    Thanked by (1)SashkaPro
    Mikael Krantz
