microLXC Public Test
1181920212224»
    @Neoon said:
    PK is back online, I am sorry for the downtime, but it took 14 days+ for a ticket response.
    Wow, that was fast! Usually it should take 1 to 2 months...
    Comparing it to Virmach, its actually fast.
    Thanked by (2)ElonBezos jcn50
    NZ connectivity issues on IPv4 should be solved too.
    Ticket took a bit to find the cause.
    Thanked by (1)jcn50
    Just a short PSA, I was busy.
    Yes PK is down, and yes its down since yesterday.
    Ticket is open since yesterday, they are still working on a resolution.
    Thanked by (1)jcn50
    They are away to celibate CNY (cause right after that, month of Ramadan starts) :lol:
  • Unfortunately, I do not meet these requirements.
  • @Neoon can help to check on the alpine config when you are free?
    Running free -h reports the host's memory in alpine, not the guest alpine OS, while cat /sys/fs/cgroup/memory.max shows the memory correctly. Probably some config issue or some weirdness with Alpine itself...
    lxc5d7a7b88:~# free -h
                  total        used        free      shared  buff/cache   available
    Mem:           7.7G        5.8G      535.7M      361.3M        1.4G      246.5M
    Swap:             0           0           0
    lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.max
    268435456
    lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.current
    27455488
    Swap:             0           0           0
    268435456
    27455488
    Some applications show incorrect memory usage in containers.
    Not something I know I can fix.
    edited March 10
    NZ is available again.
    New packages for NZ should be released tomorraw.
    Other locations will be restocked this week, if possible.
    Thanked by (1)jcn50
    New Packages are live, Storage has been increased up to 10GB.
    Update on PK:
    I got a reply on my second ticket, this time it wasn't auto closed.
    Apparently its fixed but the VM is still down, I can't access their website right now, so I can't check anything.
    According to them, they lost track of the ticket.
    Anyway, I keep you updated.
  • somiksomik OG
    edited 6:32AM
    @Neoon said:
    Update on PK:
    "Sorry, too busy bombing Afghanistan and lost track of your ticket".
    • (probably) the support team :lol:
    Restocked: Tokyo, Singapore, Bratislava and Valdivia
