Help required (windows server2012)
Hi,
i had to migrate one of my windows server active user list to another server i m not familiar with windows  if anyone had experience so please share it how to move users between two server only users i want move not the data
Never had to do this myself yet, but I remember saving this to my bookmarks: Active Directory Migration Tool (ADMT)
And maybe this guide goes along with it: http://www.rebeladmin.com/2019/01/step-step-guide-migrate-active-directory-2012-r2-active-directory-2019-powershell-guide/
You can install "Backup and Restore" tool from Feature Manager.
Then create backup of users with custom option and exclude data like desktop, etc.
Dewlance - Affordable Shared/Reseller/Master Reseller Hosting
WHMCS Addon - DemoTiger Video KB - Tutorial Videos for Hosting Providers.
Is the server joined to a domain or stand-alone?
What exactly do you want to move? Only the username/password?
If you copy/grab the profile folders you will get settings for installed applications and such, things that are installed in the user profile.
Since you say you don’t want to move data.
Its was used for only desktop uploading downloading nothing else it had i want to switch the provider bcz current one had a few network issue so i want to go with another one what i want i just want the username/passwords so i dnt need to be setup every single user again manually i dont need any other thing to be sifted
it will move all data too i dont want the data i just want the username/password only
To my knowledge (as I've never tried it) you can't copy the password between stand-alone servers. (unless using option 1 below)
It would be easier if both were AD-joined but that is another cost (separate AD-server needed).
You also need to copy all groups from the first server and create them on the second server.
On the old server, I would use Powershell commands to get the lists of users/groups/membership into a csv file(s)
and then, on the new server use the following commands with data from the csv file(s):
Create random passwords and assign to each LocalUser and send them to the users, and password change on the first login.
Thanks for the solution @mikho
