function_exists('json_encode') returning false in php70 (cPanel)
This is strange.
I've setup cPanel with TuxCare's php70 packages and the server is unable to find the json_encode/decode functions.
Any ideas where to check?
  • Solved.
    I had to enable the extensions in /opt/alt/php70/etc/php.d/default.ini
    Fuck cPanel.
  • Why not upgrade to PHP 8.x while you are at it?
    Not my code. And it's the worst code I've ever seen on a simple website.
