Enpass Lifetime Deal seems to be shortly back in stock after having been removed previously
After Enpass has removed the lifetime deal from their Website and Stacksocial a while ago (to my knowledge), it seems to be now temporarily back on their official website for some 64€:
https://www.enpass.io/pricing/
Good.
I'm glad I got it for $10 years ago 😅
Whats wrong with using self hosted Bitwarden/Vaultwarden? I mean why on earth would i trust rando companies with my data on their server?
There's nothing wrong with Bitwarden/Vaultwarden. They're great options.
You don't have to use Enpass. That said, Enpass also supports local/wifi sync, WebDAV and other methods. Vault is stored online encrypted and only decrypted on device (not online).
It's worked well for me over the years. 80-90% of users probably use Google Pw Manager in Browser or Apple's Built-In. Others use software like Enpass, OnePassword etc, and others self-host. There are many options and you'll have to decide for yourself what you're comfortable with using. For me, Enpass fit my needs 5+ years ago and still works great. No need for me to switch, really.
Bitwarden app also allows local/wifi syncs. They also support 2FA and webauth. Similarly, vault is stored on server but decoded client side (on device). So I guess Enpass is similar to Bitwarden's online (non-selfhosted) service.
I've been using bitwarden/vaultwarden only for the last 2 or 3 years. Before that, I used to use the google chrome's password save feature for things i did not care about until I learned that it can be hacked and all your passwords be stolen...
Sounds like a solid switch. Especially, because Chrome pw save is only for Browser and not for applications or other logins. That said, I've heard google pw manager became safer as you can now apparently encrypt all passwords with your biometrics or otherwhise so that just a hijacked cookie session or browser steal isn't enough anymore to see/view all passwords. That said, it's probably still best to resort to other pw managers.
