Enpass Lifetime Deal seems to be shortly back in stock after having been removed previously
After Enpass has removed the lifetime deal from their Website and Stacksocial a while ago (to my knowledge), it seems to be now temporarily back on their official website for some 64€:
https://www.enpass.io/pricing/
Thanked by (1)Wonder_Woman
  • Good.
    I'm glad I got it for $10 years ago 😅
  • Whats wrong with using self hosted Bitwarden/Vaultwarden? I mean why on earth would i trust rando companies with my data on their server?
    edited March 29
    There's nothing wrong with Bitwarden/Vaultwarden. They're great options.
    You don't have to use Enpass. That said, Enpass also supports local/wifi sync, WebDAV and other methods. Vault is stored online encrypted and only decrypted on device (not online).
    It's worked well for me over the years. 80-90% of users probably use Google Pw Manager in Browser or Apple's Built-In. Others use software like Enpass, OnePassword etc, and others self-host. There are many options and you'll have to decide for yourself what you're comfortable with using. For me, Enpass fit my needs 5+ years ago and still works great. No need for me to switch, really.
    Bitwarden app also allows local/wifi syncs. They also support 2FA and webauth. Similarly, vault is stored on server but decoded client side (on device). So I guess Enpass is similar to Bitwarden's online (non-selfhosted) service.
    I've been using bitwarden/vaultwarden only for the last 2 or 3 years. Before that, I used to use the google chrome's password save feature for things i did not care about until I learned that it can be hacked and all your passwords be stolen...
    Sounds like a solid switch. Especially, because Chrome pw save is only for Browser and not for applications or other logins. That said, I've heard google pw manager became safer as you can now apparently encrypt all passwords with your biometrics or otherwhise so that just a hijacked cookie session or browser steal isn't enough anymore to see/view all passwords. That said, it's probably still best to resort to other pw managers.
    Google Password Manager works for applications.
  • edited March 29
    If someone is currently using Google Password Manager, is there any compelling reasons to change (and what are they)?
    And if one does change, and is looking for the same ease of use and no self-hosting, what is the best option?
    Good to know. Haven't used it in a while.
    It just works on my laptop and in my mobile. Nothing to do and my passwords are there.
    I believe the data in there is not truly end to end encrypted by default if this is something you're concerned about.
  • edited March 30
    That's true by default, but you can enable end to end encryption with a setting.
  • Just switched over to Vaultwarden and Brave. Loving it.
  • I'm using Bitwarden, I was gladly paying premium for the good level of service, but they doubled the price with no real improvement, so I'm looking into having VaultWarden self hosted now.
    The river runs towards the sea, but the sea is never full...
  • somiksomik OG
    edited 12:40PM
    Install docker & docker compose. thæn use the following docker-compose.yml file to spin up your vaultwarden docker container:
    volumes:
      vaultwarden_data:
    services:
      vaultwarden:
        container_name: vaultwarden
        image: vaultwarden/server:latest
        restart: unless-stopped
        volumes:
          - vaultwarden_data:/data
        ports:
          - 80:80
        environment:
            # This is required to allow vaultwarden to verify the TLS certificate!
          - DOMAIN=https://mypasswords.unsafe-domain.com
    Or if using docker command line:
    mkdir ./vaultwarden_data
    docker run -d \
      --name vaultwarden \
      --restart unless-stopped \
      -p 80:80 \
      -v ./vaultwarden_data:/data \
      -e DOMAIN=https://mypasswords.unsafe-domain.com \
    volumes:
      vaultwarden_data:
    services:
      vaultwarden:
        volumes:
        ports:
          - 80:80
        environment:
    docker run -d \
      -p 80:80 \
    I invested some time installing Dockploy weeks ago, so yesterday I thought: maybe I have some minutes to test vaultwarden.
    Pasted some lines and deploy!
    And there was no way back.
    Tagging @AnthonySmith to report @imok for use of docker :lol:
