Heavy-Duty Dedicated Servers with High RAM & NVMe Storage
leapswitch
Hosting Provider
Need a dedicated server that’s fast, affordable, and actually ready when you order it? We’re offering India + global locations with upto 32 GB RAM & upto 10TB Bandwidth, SSD storage, and no setup fees — just clean, powerful infrastructure from day one.
The Deal:
Deal #1: E3 1230 v3 - 3.40 GHz | 4 cores | 32GB DDR3 RAM | 2 x 480 GB SSD| 10TB Bandwidth on 1Gbps | ₹4929 or $62
Why Choose Our Dedicated Servers?
* Powerful High-Speed Processors
* Generous RAM for Seamless Performance
* Lightning-Fast SSD & NVMe Storage
* Multiple OS Options to Suit Your Needs
* IPMI/KVM Over VPN for Full Control
* Free BGP IPv4/IPv6 Announcement under your ASN at a Tier 4 Certified Data Centre in Mumbai
* Same Day Delivery
With Leapswitch Networks, you get top-tier server performance at unbeatable prices. Elevate your hosting experience today!
Need a custom solution or have questions?
Call: +91 9599656657 | Email: [email protected] | Chat: www.leapswitch.com
Is the server in this offer using nvme storage?
E3 1230 v3 => IMO unlikely, unless there's some very specific motherboard or PCIe adapter installed.
Also NVMe boot would be either impossible or tricky.
☰ BF Storage — AMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref) [Final stock, then price 🠙]
As such I'd say the title is misleading.
Order links are misleaping as well, so technically you can't order anything wrong in this thread.
But I'd just leave all this to the OP.
PM sent to fix post.
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA, USA.
FREE tokens on sign up, try before you buy. | Join us on Reddit
480 gb ssd is only sata ssd
Hi, Apologies for the misleading links. Happened due to typo error. You can place the order or check the details of the server now from the link.
Hi @AnthonySmith, the post is fixed. Thanks for pointing this out. We would be happy to serve you.
Your title still claims "NVME storage", while your post body contains no such thing.
Its a repeated pattern from OP
Well, it also says "high ram" and 32GB of DDR3 is not very high...
On a technicality that's subjective, but this is advertising "nvme storage servers" while not having any of those in the offer.
Also, have you seen current memory market? I'd say 32gb is "high ram" nowadays :P
So you had to remind me...
If anyone needs me, I'll be in the corner crying because I can't afford to replace my broken laptop. 💸💸💸
