Block Storage / local Storage limited offer new Ryzen!
key900key900 OG
edited March 2020 in Offers
Our first offer here should be something good. So here is our last new offers
Note: Limited to 1 per client due low availability .
RB1
  • 1 GB Dedicated RAM
  • 1 x CPU core Ryzen 3900x
  • 20GB NVME Disk
  • FREE 125Gb Block Storage ( UP to 3TB for $5)
  • 5TB/Month @ 1 Gbps Shared( capped the connection speed to 10mbit when bandwidth exceeded.)
  • 1x IPv4
  • Private Internal IP
  • KVM
  • $3.30/month Upgrades are available for small fee
Los Angeles (https://my.letbox.com/cart.php?a=add&pid=117)
RSB1
  • 256GB raid10 Disk ( UP to 3TB for $5)
  • 1x IPv4
  • KVM
Los Angeles (https://my.letbox.com/cart.php?a=add&pid=118)
Free Bonus :
  • A + B power Feeds
  • 10Gbps Uplink
  • Free 5 Minutes Server Monitoring + Blacklist (Email and SMS alert) Read More
  • Custom ISO Available (Windows , linux etc.. )
  • Preinstalled OS
  • 2Gbps DDoS-Shield Mitigation
  • IPV4 rdns Management
  • /64 IPV6 up on request
  • Enterprise NVMe
  • Triple Replicated Block Storage
Pv6 Address Space
Best regards
*SeedFiles.Com Make it Simple! Coming Soon. Discord Community https://discord.gg/CgYNcTMY
  • @key900 do you aware this server can handle nextcloud/owncloud for single user?
    I saw 20% CPU socket on your cart.
    nice offer mate <3
    Thanked by (1)key900
  • mobilemobile Retired
    put LowEndSpirit in How did you hear about us? please
    Syncthing will use more than 20% of single core if it's hugging more than 2TB of files (assuming files are 400-700MB each) so uh..... i guess the nvme one is legal to use more than 20% most of times?
  • Very good offer. Do you intend to launch these plans in Dallas?
    Thanked by (1)AlwaysSkint
  • Nice offer. BUT
    2 TB (2000 usable) $5.00 USD
    3 TB (3000 usable) $5.00 USD
    What?
    And the looking glass never worked, down for more than 1 year., LA 80 port closed, certificate expired.
  • @let2les said:
    Nice offer. BUT
    What?
    Have you see that we said limited offer? Once it expired any new orders for extra 3tb will be increased.
    For the LookingGlass we are used Psychz you can test from here
    https://lg.lax.psychz.net/
    Regarding the port 80 of what exactly? And what certificate you are referring to? I don’t see any certified expired.
    Thanks.
    We hope so.
    I don’t do that test.
    Well not exactly and the 20% it not the really limitations however we cannot allow to puch the cpu 24/7 .
    Regarding
  • @key900 said:
    Regarding the port 80 of what exactly? And what certificate you are referring to? I don’t see any certified expired..
    lg.la.letbox.com
    seems neither LA or DL supports https though, but your LA web server listens to 443 and has an invalid certificate. Dallas lg IPv4 works, but IPv6 version not working, not ping6 or mtr6 or tracerouter6.
    psychz is much better and straightforward.
    Just to make sure, all incoming traffic is free, right?
    Asked for a prior promotion, In and out are both metered on the same quota
  • key900key900 OG
    edited March 2020
    @let2les said:
    lg.la.letbox.com
    Hello,
    Where exactly get the lg.la ? We no longer use it you can check our kb did you see in anywhere at our website? . If you find anything at our website not working just notification me.
    Dallas one is old and not updated for long gone now. We will update it as soon as possible, And if you check the our Kb will see that we don’t use https for the lg.
    Again where is the 80 blocked exactly?
    I was using an outdated lg for LA, when I tried to connect to lg.la.letbox.com, I found 80 refused and 443 certificate expired, that's all.
    For the Dallas one, the issue is lacking IPv6 support. I assume the Dallas one is from Psychz too?
  • Many tests on Psychz's looking glass not working either. Sigh, why most providers' looking glasses just suck?
  • key900key900 OG
    edited March 2020
    Psychz LookingGlass works fine but seems their IPv6 not with me/ Dallas already updated.
  • Processor: AMD Ryzen 9 3900X 12-Core Processor CPU cores: 4 Frequency: 3792.874 MHz RAM: 3.9G Swap: 92M Kernel: Linux 4.15.0-91-generic x86_64 Disks: vda 20G HDD vdb 500G HDD CPU: SHA256-hashing 500 MB 1.799 seconds CPU: bzip2-compressing 500 MB 3.937 seconds CPU: AES-encrypting 500 MB 0.785 seconds ioping: seek rate min/avg/max/mdev = 43.9 us / 228.3 us / 4.63 ms / 74.7 us ioping: sequential read speed generated 19.1 k requests in 5.00 s, 4.66 GiB, 3.82 k iops, 954.0 MiB/s dd: sequential write speed 1st run: 2193.45 MiB/s 2nd run: 2098.08 MiB/s 3rd run: 2098.08 MiB/s average: 2129.87 MiB/s IPv4 speedtests your IPv4: 144.172.xx.xxxx Cachefly CDN: 95.24 MiB/s Leaseweb (NL): 16.60 MiB/s Softlayer DAL (US): 62.12 MiB/s Online.net (FR): 14.87 MiB/s OVH BHS (CA): 30.98 MiB/s No IPv6 connectivity detected -------------------------------------------------
    Yet-Another-Bench-Script
    v2020-02-10
    Sun 29 Mar 2020 11:38:12 PM EDT
    Processor : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores : 1 @ 3792.874 MHz
    AES-NI : ✔ Enabled
    RAM : 987Mi
    Swap : 0B
    Disk : 20G
    Running fio random mixed read + write disk test with 4kb bloRunning fio random mixed read + write disk test with 64kb blRunning fio random mixed read + write disk test with 512kb bRunning fio random mixed read + write disk test with 1mb blofio Disk Speed Tests (Mixed R/W 50/50):
    Block Size 4kb (IOPS) 64kb (IOPS)
    Read 390.23 MB/s (97.5k) 850.26 MB/s (13.2k)
    Write 391.26 MB/s (97.8k) 854.73 MB/s (13.3k)
    Total 781.49 MB/s (195.3k) 1.70 GB/s (26.6k)
    Block Size 512kb (IOPS) 1mb (IOPS)
    Read 1.00 GB/s (1.9k) 1.06 GB/s (1.0k)
    Write 1.05 GB/s (2.0k) 1.13 GB/s (1.1k)
    Total 2.05 GB/s (4.0k) 2.20 GB/s (2.1k)
  • vyasvyas OGSenpai
    edited March 2020
    Nice
  • Yes. This a great value deal. NVME + storage + ryzen.
    Spoiler
    OS : Debian GNU/Linux 10 (64 Bit)
    Virt/Kernel : KVM / 4.19.0-6-amd64
    CPU Model : AMD Ryzen 9 3900X 12-Core Processor
    CPU Cores : 1 @ 3792.874 MHz x86_64 512 KB Cache
    CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled
    ## Geekbench v4 CPU Benchmark:
    Single Core : 5468 (EXCELLENT)
    Multi Core : 5277
    ## IO Test
    CPU Speed:
    bzip2 : 135 MB/s
    sha256 : 289 MB/s
    md5sum : 637 MB/s
    RAM Speed:
    Avg. write : 3276.8 MB/s
    Avg. read : 10274.1 MB/s
    Disk Speed:
    1st run : 1.8 GB/s
    2nd run : 1.8 GB/s
    3rd run : 1.8 GB/s
    Average : 1843.2 MB/s`
  • Can existing intel users be migrated to ryzen?
  • So the core can burst to 100% for what? Like 20mins hopefully, before being throttled.
    That would be nice.
  • @key900
    When you say "256 GB (200 usable)", you actually mean (250 usable), no?
    Sorry no
    That would be nice.
    Yes something like
    @AlSwearengen said:
    @key900
    Yep that’s right just typo and fixed.
    Regarding
