Enpass Lifetime Deal seems to be shortly back in stock after having been removed previously
2»
  • somiksomik OG
    edited April 5
    The only thing I don't like is that I don't have a password generator handy for temporary passwords, like Enpass does.
    Erm, you don't?
    There are so many free password generators online.
    Infact, if you are using vault warden with bitwarden app, why not add the bitwarden extension to your browser? You'll get access to everything in your vault and still be able to use username/password generator.
    Failing that, you can even use the online password generator that bitwarden offers on their website:
    https://bitwarden.com/password-generator/
  • Thanks. I didn't notice it.
    Thanked by (1)skorous
  • Bitwarden extension has some integration with Addy.io to create a new alias based on the current website.
    That is nice to generate credentials unique for each site.
    It can be done manually, sure, but for those that does not enable catch all, that integration is really useful.
    I might try to get a working version of a MXroute alias integration (I usually have their extension do that work)
    Thanked by (1)imok
    The river runs towards the sea, but the sea is never full...
  • skorousskorous OGSenpai
    @motafokabr said: Bitwarden extension has some integration with Addy.io to create a new alias based on the current website.
    It does? Where at? I've somehow missed this.
  • @imok said:
    I was using Enpass and Google Passwords.
    • I can store passkeys (not sure if Enpass could do that)
    Great and detailed answer, thanks :)
    Enpass stored passkeys. :)
    Just created a passkey with Enpass for Google Acc yesterday, so can also confirm😂
