The only thing I don't like is that I don't have a password generator handy for temporary passwords, like Enpass does.
Erm, you don't?
There are so many free password generators online.
Infact, if you are using vault warden with bitwarden app, why not add the bitwarden extension to your browser? You'll get access to everything in your vault and still be able to use username/password generator.
Autofill on Chrome (Android) stopped working since a while on Enpass. Kinda annoying, but Brave and Firefox works just fine, so I'll probably just use that.
Failing that, you can even use the online password generator that bitwarden offers on their website:
https://bitwarden.com/password-generator/
Thanks. I didn't notice it.
Bitwarden extension has some integration with Addy.io to create a new alias based on the current website.
That is nice to generate credentials unique for each site.
It can be done manually, sure, but for those that does not enable catch all, that integration is really useful.
I might try to get a working version of a MXroute alias integration (I usually have their extension do that work)
The river runs towards the sea, but the sea is never full...
It does? Where at? I've somehow missed this.
Great and detailed answer, thanks
Enpass stored passkeys.
Just created a passkey with Enpass for Google Acc yesterday, so can also confirm😂
Look for the username tab on generator
Holy crap it does. I'd totally managed to ignore that tab. TY.
That is a Chrome on Android issue...
Yup, Google said as much
