If Anyone is interested [site/server specs]
123457»
  • Yeah when I get the means I will be automating that through code, i.e. no links possible posts until 10+ posts and 7+ days registered, no wall posts either until a minimum threshold.
    Also 0 post accounts will also no longer see the de'indexed stuff, 0 posts accounts older than 12 weeks will be auto purged etc.
    keep things tidy and accurate.
    Thanked by (3)uptime lgsin verjin
  • What are the updates now? And which monitoring tool are you using Ant?
  • Sure I will do a bit longer range update, I just use runclouds stats, vanilla stats and google analytics.
    Thanked by (2)tarasis uptime
    Congrats on that decent resource usage.
    Some stuff that I have running runs on quite big machina which is a big overkill.
    Better let it run on small machina..
  • yeah I know 2GB is overkill for this forum, but I figured that is probably the maximum it will ever need to run at peak and also run the backups at the same time without end user disruption.
    Thanked by (1)tarasis
  • The usage is much less than I expect for running a forum.
  • @AnthonySmith said: Also 0 post accounts will also no longer see the de'indexed stuff, 0 posts accounts older than 12 weeks will be auto purged etc.
    Thats a bit harsh....i enjoy reading while logged in....since i dont have much to talk or issue to discuss,thus not much/none posts were made...even on let,i made first post a few month after registered...and that when i have an issue with my server....
    Thanks....=D
    @AnthonySmith If it is not too crazy to imagine that you can find the time, maybe it might be nice for everyone to see an updated version of the visitor analytics and also the server load statistics? Maybe for TLES and now also for the new LES site too?
  • vyasvyas OGSenpai
    edited May 2020
    Thanks....=D
    You just posted so you are good for another 11 months now. That doesn’t seem harsh
    Cheers
  • Last 24 hours top 5 countries:
    Thanked by (3)Ympker Not_Oles uptime
