What do you think about hCaptcha?
2»
  • @debaser said:
    @Janevski said: That's because you're not a cyborg.
    You sound just like my ex-wife now.
    Awwww...
    Thanked by (1)debaser
  • @Clouvider said:
    It seems to prompt more iterations of tests than reCaptcha does.
    @rcy026 said:
    If I had privacy concerns, I would not use Cloudflare either.
    Just imagine the amount of data they are able to collect if they want to.
    @sanvit said:
    @verjin said:
    Cloudflare switches to hCap because reCap (google) is tracking end users then what it this?
    What on earth they are doing? Privacy badger is blocking hCap because of tracking! :anguished:
    I believe it's because of Google wanting to monetize reCAPTCHA
    I don't blame Google for wanting to monetize their products, and it totally makes sense to change policies for them, but it's a shame because there aren't many (good) alternatives out there.
    They make (or will make) a ton of money with every site using reCaptcha. I think their AI driving dataset is even bigger and better than teslas'.
    SEO Software
    Cheap SSD Hosting
    Web Scraping API
    https://ecosia.org Plant trees from your keyboard.
  • I solved some hCaptcha recently and I didn't find it difficult. Two pages though, but I don't mind those 2-3 extra seconds. Privacy concerns with Google: Yes. And not because I have things to hide (take for example this guy)
    Thanked by (1)g4m3r
  • It's like a GF. Too. many questions and you can't ignore it :tired_face:
