So, what are you hosting on your EUServ free IPv6 VPS?
So, those of you who haven't cancelled it (yet): What are you hosting on there?
Even though specs and performance are not great I am thinking about signing up. Maybe host a small static website and use CF IPv6 to IPv4 tunnel or see if there is some other cool projects on awesome-selfhosted.
I know there's many ppl of you who signed up for it, so let's see.
Tagging @tarasis @thagoat @cybertech @Iroshan464 @VPS
the usual destiny of all my VPSs.
Idling....
Monitoring.
Sounds like an honorable project. Might consider that as well
@benj0x Which monitoring did you setup? PHPServermon?
I'll just add to my http proxies pool for crawling.
smokeping & statping
I'm finally playing around with https://github.com/mettke/ssh-key-authority.
Unfortunately, I only have one SSH key to manage
Interesting Thanks for sharing!
I gave mine to someone else. Didn't bother grabbing one. I don't need it.
i signed up,but didn't received the vps yet? How long it takes? its more then 2 days now im waiting.
Until they've verified your order. Sometimes it takes longer. Just contact their support when you're waiting longer than 3 days. They'll help you out for sure.
idling
I wanna thank all the idlers on the same node as me that will bring down the load and let me experience more speed.
@foxone
You're welcome ?
tough if your isp doesn't have ipv6 .
You can always run a wireguard instance in a VPS with ipv6 and access via it. I too don't have direct ipv6 support.
Personally I can't think of anything I would want hosted there that I wouldn't just pay something really little for instead and have hosted properly
i wanted to use it to try different admin-panels, but ipv6-only turned out to be a big annoyance since many donwloadsites still rely on ipv4
then i wanted to use it as an external DB server for my other VPSes, but since they are all lowend they also rely on IPv4 and cant reach it
[deleted]
use v2ray + cloudflare (v4-->v6)
https://guide.v2fly.org/en_US/advanced/cdn.html
and use dns64 (https://nat64.xyz),ipv6 vps can visit ipv4-only website
