Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Hitachi/HGST Ultrastar 7K4000
Device Model: HGST HUS724020ALA640
Serial Number: PN2181P6J3Z9XP
LU WWN Device Id: 5 000cca 22dddfdf0
Firmware Version: MF6OABY0
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue May 26 10:43:55 2020 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Thanks a lot Iroshan464. The information is enough for me. It is like a mini netbook but with a larger disk The configuration appears to be good for certain types of systems.
The wise receive respect. The dumb demand respect.
150-180MB/s if it's an enterprise drive.
What's there to say?
Also 150 IOPS maybe
I think I have a KS3.
Let me check.
A simple netbook. ?
Linux kim 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1+deb10u1 (20--------------------------------------------------------------------------- OS : Debian GNU/Linux 10 (64 Bit) Virt/Kernel : Dedicated / 4.19.0-8-amd64 CPU Model : Intel(R) Atom(TM) CPU N2800 @ 1.86GHz CPU Cores : 4 @ 1456.932 MHz x86_64 512 KB Cache CPU Flags : AES-NI Disabled & VM-x/AMD-V Disabled Load Average : 0.00, 0.00, 0.00 Total Space : 1.8T (4.1G ~1% used) Total RAM : 3929 MB (111 MB + 162 MB Buff in use) Total SWAP : 2046 MB (0 MB in use) Uptime : 0 days 1:36 --------------------------------------------------------------------------- ASN & ISP : AS16276, OVH SAS Organization : OVH SAS Location : Gravelines, France / FR Region : Hauts-de-France --------------------------------------------------------------------------- Performing Geekbench v4 CPU Benchmark test. Please wait... ## Geekbench v4 CPU Benchmark: Single Core : 644 (POOR) Multi Core : 1327 ## IO Test CPU Speed: bzip2 : 25.0 MB/s sha256 : 47.1 MB/s md5sum : 192 MB/s RAM Speed: Avg. write : 460.0 MB/s Avg. read : 1365.3 MB/s Disk Speed: 1st run : 127 MB/s 2nd run : 127 MB/s 3rd run : 128 MB/s ----------------------- Average : 127.3 MB/s ## Global Speedtest Location Upload Download Ping --------------------------------------------------------------------------- Speedtest.net 94.25 Mbit/s 93.71 Mbit/s 8.619 ms UK, London (toob Ltd) 96.01 Mbit/s 93.74 Mbit/s 4.934 ms France, Lyon (SFR) 97.16 Mbit/s 93.06 Mbit/s 10.568 ms Germany, Berlin (DNS:NET) 94.55 Mbit/s 93.19 Mbit/s 19.520 msEnjoy meditation without religion for one month.
Thank you very much for the data.
If it is not a great trouble, could you please post the output of "smartctl -i /dev/sda"?
