Problem with iptables-legacy NAT
I am able to get iptables NAT working on InceptionHosting Netherland node, but not on London and Phoenix.. All three nodes are installed with Debian 10 and have the same packages and configuration.
Is there any special configuration that I need?
On London and Phoenix:
[email protected]:~# iptables-legacy -t nat -L
iptables v1.8.2 (legacy): can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
[email protected]:~# lsmod | grep iptable
iptable_security 4242 -2
iptable_nat 4242 -2
nf_nat_ipv4 4242 -2 iptable_nat
iptable_raw 4242 -2
iptable_mangle 4242 -2
iptable_filter 4242 -2
ip_tables 4242 -2 iptable_security,iptable_filter,iptable_mangle,iptable_nat,iptable_raw
[email protected]:~# uname -a
Linux phx.vps 4.19.0 #1 SMP Mon Mar 16 15:39:59 MSK 2020 x86_64 GNU/Linux
[email protected]:~# cat /etc/debian_version
10.4
On Netherland Node:
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- anywhere anywhere
iptable_raw 4242 -2
iptable_nat 4242 -2
libkmod: ERROR ../libkmod/libkmod-module.c:1931 kmod_module_get_holders: could not open '/sys/module/virtio_ring/holders': No such file or directory
ip_tables 4242 -2 iptable_filter,iptable_mangle,iptable_nat,iptable_raw
Linux nl.vps 4.19.0 #1 SMP Thu Jun 27 15:10:55 MSK 2019 x86_64 GNU/Linux
10.4
make sure iptables is installed and check the knowledge base, run: touch /option.netfilter the wait 30 minutes and test again.
maybe refer to this knowledgebase first (if it's Inception Hosting NAT)
Thanks! touch /option.netfilter did the trick.
