Phoenix Double Storage || NAT Bundle || UK KVM 256MB €10 /year || UK KVM 2GB €29.95 /year
edited August 2020 in Offers
I have just finished doing a big audit of everything, I have some irregular space, due to plan size changes over the years and some nodes being almost full but still some space left from cancellations etc so I thought I would do a bit of a mix.
Please note these will last until I need to stop them I can't put a specific time scale on it, they could vanish in an hour some might still work in 2 weeks.
I have tried to make them appealing to the LE* crowd.
Phoenix Storage plans
All plans from the KVM500 and bigger get double the advertised storage space automatically, for example, the KVM500 plan gets 1000GB and costs €6.25 for 3 months.
Order Link: https://clients.inceptionhosting.com/cart.php?gid=30
sold out
NAT Bundle
€8 /year for all 3.
Netherlands, Phoenix USA and London UK.
OpenVZ 7
* 1 CPU Core
* 128mb Ram
* 2GB Disk Space
* 350 GB Transfer p/Month
* /64 IPv6 range
* 1 x NAT IPv4
* Orders manually accepted within 24 hours - not instant setup
NOTE: You need to set up each product one at a time, you will be taken to the next location when you complete the first, please use a minimum of 4 characters in the hostname or provisioning will fail and setup will be significantly delayed.
Order Link: https://clients.inceptionhosting.com/cart.php?a=add&bid=19
UK SSD Cached KVM 256MB
€10 /year
  • 2 CPU Cores (Equal Share)
  • 256 MB Ram
  • 10 GB SSD Cached Disk space
  • 350 GB Bandwidth @ 1 gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
Order Link: https://clients.inceptionhosting.com/cart.php?a=add&pid=175
UK SSD Cached KVM 2GB
€29.95 /year
  • 4 CPU Cores (Equal Share)
  • 2 GB Ram
  • 40 GB Disk space
  • 2000 GB Bandwidth @ 1 gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
Order link: https://clients.inceptionhosting.com/cart.php?a=add&pid=164
Terms tl;dr
  • No tor
  • Torrent abuse report = bye bye
  • No open proxies
  • No auto click/scam bots
  • No crypto mining
  • No bulk mailing
  • If you don't actually read the terms they still apply
  • Orders will be auto rejected if placed via a proxy or VPN
You cannot swap/change your current plan/product to any of these but you are obviously welcome to cancel the current ones and take one of these, you will not get any credit though, I am able to do these in limited quantities only.
  • This is an important selling point and it should be stressed that DirectAdmin is included in all UK locations.
    Thanked by (1)vimalware
  • FAT32FAT32 OGSenpai
    Including UK NAT? :joy:
    Thanked by (1)skorous
    It's included, but you can't apply because you need to ticket Anthony your IP Address.
    If you want a free license then please open a support ticket with the following information:
    Server hostname:
    IP Address:
    Operating System:
  • Great offer! Storage plan is especially tempting, but I have no idea about SSHFS performance with the high latencies to the US. Any thoughts?
  • 2€ per terabyte (500GB double deal) is great. Will you also bump the monthly data traffic limit accordingly?
    yep, forgot to mention that :)
    @Bochi said: Any thoughts?
    Obviously performance is not great in terms of write speeds but it works.
    @rajprakash said: Will you also bump the monthly data traffic limit accordingly?
    Nope, keeping the shirt on my back this time thanks :)
    Thanked by (1)rajprakash
  • edited August 2020
    do you have lg for phoneix or test ip? found from other thread nope they were not ips :/ :)
    i think specs should be sufficient for a nextcloud install?
  • @tridinebandim said: i think specs should be sufficient for a nextcloud install?
    more than sufficient
    Thanked by (1)tridinebandim
    It would be a good spot for backups of your primary storage location (EU?). Write-only incrementals do not count against the transfer quota at all.
    Tis an unbelievable deal for less than usd 2.5 per Terabyte of RAID6 .
    Thanked by (2)rajprakash lgsin
  • I was waiting for the UK storage but I finally caved and got a KVM500. The best part is it's not a yearly commitment so even if my ISP has garbage routing to Phoenix I won't be mad at myself that bad for not checking before buying :tongue:
    Great offer! Can't wait to set it up.
    I caved too ??. I figure with my 10mbps upstream cap, even USA is fine for workstation borgbackup remotes.
    Please let people know how you get on, the new storage offers in Phoenix I feel are quite different from the old ones and it would be great to get some feedback.
  • Hi I saw your post in Hostedtalk, I am newhere. I posted over there, I had a question, that the storage KVM500 is a little less than the next tier up? I am looking for 2tb of storage but i'm confused about the pricing. Would there be anything stopping me from getting two plans?
    Oh, nice spot, looks like I underpriced the KVM500, not sure what I was thinking, the plans recently changed, must be why so many people jumped on that plan.
    I am a bit tired tonight I will look at it with fresh eyes tomorrow, no problem buying 2 though but they won't be merged. :)
    Should I be worried that the SolusVM for Phoenix seems to record data transfer usage, even for incoming flows?
    I don't know anything about SolusVM. Can it be configured to avoid metering incoming transfers?
    Edit: I've added my own vnstat logging for now.
    fixed.
    Ok, that makes sense! If you can take a look tomorrow and maybe adjust or offer a discount code for the next tiers that would be cool :)
    Erm, it’s the KVM500 that is to low, there is no discount it is a double storage offer :)
  • Is there any way to test the network performance (eg. looking glass or test files)? 1TB for 25€/y sounds tempting, I would prefer EU/UK tho. But for backup purposes it would be a nice machine... I canceled my NAT bundle weeks ago, so I can't test it myself apparently. Any help is appreciated
    http://148.163.68.178/1g.bin
    Thanked by (2)schnafi bdl
  • IOFLOOD Phoenix is listed on the speed test app too as a location.
    Thanked by (1)bdl
    In June madness thread, I bought one KVM500. I know it's double storage now. Could have waited ?
    They are close in price, however note that the KVM500's price is for three months and the KVM1000 is monthly...
  • Storage offer over
  • vyasvyas OGSenpai
    edited August 2020
    Storage offer over
    Congratulations, looks like you sold out soon!
    okay now I am FOMO'd. :-)
    after the flowvps mail, was planning to sign up.
    Ah! Next time
  • @vyas said:
    Storage offer over
    Congratulations, looks liek you sold out soon!
    Ah! Next time
    I have messed something up in the pricing and the orders are flooding in, I am happy to honour anyone who purchased already but I need some time to revise and see what i have done :)
  • bdlbdl OG
    edited August 2020
    @vyas said:
    Storage offer over
    Ah! Next time
    haha me, too (re ex-Flow)... oh well, I have my host solutions 1tb service for backup :lol:
    @AnthonySmith , you're getting ioflooded! :wink:
    Thanked by (1)vyas
    This right here, is the AnthonySmith brand. ??
    Thanked by (1)bugrakoc
  • I'm surprised that this incredible storage deal lasted more than half an hour and that I managed to get one.
    @AnthonySmith Thanks for the offer and honouring the previous orders. Maybe you'd want to update hostedtalk's post too??
  • Ok I found my mistake on the storage plans, pricing updated.
    I will see what sort of offer I can bring to the table on Thursday with the updated pricing
    Thanked by (2)flips bdl
