CSF blocking custom SSH port
Hello.
I've installed Direct Admin and it comes with CSF. I've configured a custom port number in sshd_config file and CSF blocks the connection.
I don't want to whitelist my current IP because it's dynamic.
What's the best configuration for this?
    edited October 2020
    tcp|in|d=custom_port|s=IP_Address
    opens the custom port for your IP only
    If ip is dynamic, maybe u can use ur isp ip range in IP_Address
    Edit: just realized you don't want to whitelist current IP.
    Reinstall CSF for new SSH port to be included or just manually whitelist
    edited October 2020
    There is never any issue with CSF ssh custom port - just add the port to the list of other ports. Then csf -r. Change sshd_config and systemctl restart sshd
    As for dynamic IP: setup a free dyndns account (there are a few) and add your new FQDN to csf.ignore. Change the relevant dyndns entries in csf.conf -never get locked out by accident.
    Done.
    (The paranoid amongst us connect via a VPN, with a fixed IP, circumventing the dynamic IP issue.)
    Thanked by (2)skorous imok
    edited October 2020
    /etc/csf/csf.conf - or use the GUI
    TCP_IN = add custom port to the end
    DYNDNS = 600
    DYNDNS_IGNORE = On
    Correction: add your new FQDN to csf.ignore csf.dyndns
    Can I know, did you change SSH port before or after installing DirectAdmin?
  • I changed mine before and then just added it to the list of inbound ports in the CSF config page in DA.
  • To be on the safe side, I (almost) always change port AFTER installing a control panel. I think it was HestiaCP that reverted the port during install, the 1st time I installed it. :-o
    Thanked by (1)imok
  • @imok said:
    Hello.
    Do what Alibaba would have done.
    Open the port.
    Thanked by (1)imok
  • Thank you, added to TCP_IN and everything OK. Blocking failed attempts still works fortunately.
    I was in doubt because with cPanel I didn't configured it in CSF.
    @SmallWeb said: Can I know, did you change SSH port before or after installing DirectAdmin?
    @AlwaysSkint said: To be on the safe side, I (almost) always change port AFTER installing a control panel.
    I did it before installing. That may be the difference.
    edited October 2020
    @imok said: I was in doubt because with cPanel I didn't configured it in CSF.
    With cPanel, CSF is normally installed afterwards, whereby it scans for current open ports and adds the appropriate ssh one to TCP_IN. That's the default action of CSF, during its' installation. Perhaps with panels that integrate CSF during installation, there are 'tweaks' done to sshd_config after the CSF install part (not good).
    Thanked by (1)imok
    Tbh, don't recall having the same issue with DA/CSF but I uninstall and reinstall CSF by default.
    edited October 2020
    @SmallWeb said: .. but I uninstall and reinstall CSF by default
    .. which would circumvent any issue. ;) Assuming you haven't rebooted and tried to ssh in to the server i.e. used the GUI to reinstall.
    edited October 2020
    Nah, I mean I check SSH login access and common ports but just uninstall/reinstall CSF in case I miss anything not so obvious.
    Had plenty of my own fuck ups so I'm usually in VNC ready to revert.
    Thanked by (1)AlwaysSkint
    I have my own default set of CSF configs, that gets auto downloaded on every new install. Makes life easier :)
    Thanked by (2)MichaelCee AlwaysSkint
    Another thing for my to-do list! :smiley:
    Nice.
    Where can I download the instructions?
    /joke
