Hurricane Electric Free DNS
2»
  • @cochon said:
    @tetech said:
    I use HE.net and find it to be very good. I run a hidden master, so no need to worry about HE API or web interface, just change on the master and do a notify for AXFR.
    How do you find the AXFR response times, i.e. update delay, these days?
    When I looked at HE a few years back the AXFR timing seemed very erratic, changes could take ages (10's of minutes) to propagate, making it problematic for DNS based authorisation, e.g. Letsencrypt.
    I did a quick look at the last week of logs and their response to a NOTIFY seemed to be around 1-1.5 minutes behind the other slaves. Nothing drastic. Personally I am making a CNAME for LetsEncrypt records and pointing it to a subdomain at a different DNS provider which I use for that and nothing else.
    Thanked by (1)cochon
    Thanks, just realised @Brueggus had actually answered my query higher up but I didn't spot it. Might give HE another try as a backup, always heard good things about their reliability.
    Good suggestion on doing LE on another platform altogether.
    @Brueggus said:
    Never had issues in the past 5... 6... 7.. dunno years. Changes propagate in less than a minute.
  • Another HE limitation is they do not support numeric-only domains like: 1234.com
    Thanked by (1)vimalware
  • @tetech said:
    @flips said: And no anycast ...
    HE does have anycast.
    ^this
    I'm using certbot and have configured dns-rfc2136-propagation-seconds=120 which works for me. The propagation delay was about 90 seconds last time I checked. And that's the total delay from my master via my opendnssec live signer, and a slave of mine.
  • HE DNS is like, first it's free and then why fix something that isn't broken...
    Then, almost no body complaints to them, they simply switch over to something else...
