@cybertech said: @Mason I get these on and off on the same vps, root user. not sure why.
Preparing system for disk tests...chmod: cannot access './2020-11-13T15_19_27+08_00/disk/fio': No such file or directory
Interesting... I'll look into this and see what I can figure out.
Best I can come up with to explain this is that the curl command grabbing the fio binary from the github repo is failing silently, thus the chmod fails on the non-existent file. Solution that I will implement is to add the "--retry #" flag to the curl command to allow multiple retries to download it (in case the first try fails), then add some better error handling to detect if it wasn't able to grab it for some reason and either skip the disk test (if doable) or simply alert and exit safely.
Supermicro SYS-6039P-TXRT on premise
(this machine has 100Gbps network interfaces, but the Internet connection is on a 10Gbps network interface connected to a 100Mbps switch so...)
DataWagon beta testing
1 AMD Ryzen 3950X CPU Core
1GB RAM
30GB RAID10 NVME Storage
5TB Bandwidth
Chicago Datacenter
Ryzen 3600 dedi with GorillaServers:
AMD Ryzen 5 3600 3.4Ghz 6 Core 12 Thread with 4.2GHz boost
32GB DDR4
256GB NVMe
4TB HDD
1Gbps Port / 30TB outbound (unmetered inbound)
Inspire Solutions
Squats are the new Push-ups
Think I'll pull Wifx (Zurich) and Iveloz (Sao Paulo) from the network tests for now. Seems neither has worked for a couple weeks
NOVOS - Antwerp, Belgium - 512MB KVM (AMD EPYC)
I had at issue before, but worked the 2nd time
Tested on Debian 10, NYC location (Clouviders network, hence the fast iperf speeds for NYC)
George Datacenter Ryzen 1gb Amsterdam (Ryzen 5 3600X)
Hosthatch 1gb Amsterdam nvme
That’s a beast you got there.
Sounds like a VPS from you.
NexusBITS
CloudCone 11.11 promo - 11.11.20-3 deal (Node: S67) ?
In every democracy, the people get the government they deserve.
~Alexis de Tocqueville
HostEONS - 3 GB KVM Gigabit VPS deal (Node: KVM-Node19-LA)
HostUS OpenVZ VPS (Promo) - US/EU Special 3 (2GB) deal (Node: LAX01-VZ28
)(Useing ~4 years)
?? Antwerp vServer from https://novos.be
1 vCore
1GB of Ram
20GB of NVM SSD
1TB of Traffic
1 IPv4
What kind of NAS storage using AMD GX 412?
Our "Linux Jay" VPS - 1 vCore, 1GB RAM, 20GB SSD, 100 Mbit/s unmetered, 1 IPv4 - $5.59 USD /m:
XetHost | VPS, Dedicated servers, SMTP services from Hungary | We accept Bitcoin and altcoins!
Testing out some changes and tweaks before pushing code this evening
Nexus Bytes 4GB KVM in NY... she's a beaut!
@Razza, @cybertech - you guys shouldn't run into this issue again with the latest update. But PLEASE let me know if you do and I'll get it sorted!
(@seriesn issue referenced here was the same one brought up in your deal thread. should be patched now)
La De La Prem!
1TBVPS -- 8Gb RAM - 8vCPUs
would have expected prem to have passthrough or aes at least..
EUserv VS2-FREE
HostBrr aff best VPS.
We are impotent.
