KVM 3 xCoffeelake E2276G 6GB RAM 60GB NVME RAID1 SG??
Hello LES people,
Let's introduce some good Singapore KVM deals before rules kick IN!
As Ant mentioned limits be placed back in sometime (that is still 2 hrs to go) ..
VPS-KVM4G SG Preorder - The popular guy
4GB DDR4 ECC RAM
40GB NVMe SSD RAID1 disk
2vCPU CoffeeLake E2276G @3.7+ Ghz
1 IPv4 + 1TB transfer @ 1Gbps
[Just £15.6 per 3 months recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=309)
VPS-2G Preorder - notitle?
2GB DDR4 ECC RAM
20GB NVMe SSD RAID1 disk
1vCPU CoffeeLake E2276G @3.7+Ghz
1 IPv4 + 500gb transfer @ 1Gbps
[Just £21/year recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=308)
VPS-1G Preorder - The small one
1GB DDR4 ECC RAM
10GB NVMe SSD RAID1 disk
1 IPv4 + 250gb transfer @ 1Gbps
[Just £15.5/year recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=307)
VPS-KVM6G SG Preorder - The mega guy, best value for money
6GB DDR4 ECC RAM
60GB NVMe SSD RAID1 disk
3vCPU CoffeeLake E2276G @3.7+ Ghz
1 IPv4 + 1.5TB transfer @ 1Gbps
[Just £20.3 per 3 months recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=311)
1. Are these KVM VPS ?
Yes, these are KVM VPS.
What are the OS options?
We currently have Ubuntu, Debian & CentOS options available in the control panel, custom ISO are installable via ticket.Is IPv6 enabled?
IPv6 is not supported on this server right now, however you can always use a IPv6 tunnel broker like HE.
Plans to implement IPv6 in the near future.When will these be provisioned?
These VPS should be provisioned by 6th December, most probably earlier.A test IP/looking glass?
IP: 131.153.46.141
1GB test file
Any other questions? Please ask here or PM is fine too ☺️
All prices are recurring
@AnthonySmith please remove this thread if anything seems wrong.
Regards,
Abdullah
Just wonder why it's sometimes saying:
And sometimes:
Isn't it the same processor?
A typo sir, it's the same
https://webhorizon.net
Is this at Hivelocity SG?
No, at PhoenixNAP SG
Private game server + VPN allowed?
Nested virt available?
http://ping.pe/131.153.46.141
More than 200ms from Singapore (Digital Ocean) to Singapore.
vps9
hostname is available. affbrrNot for me.
GCP Singapore VM
Just for fun, from Sonora, MX
I wanted to check....
I usually succeed - from Thailand - to reach any node in SG between 8 to 12 hops..... 131.153.46.141 needs 15!
Not really sure how important it could be!
Can you share the ping traceroute?
Something wrong at gtt, I am looking into it...can you help me with how the ping is from China?
I think you mean to ask @Tigersway to share the traceroute?
By the way, do you know the reason why lines 18 and 19 (the last two lines) of the traceroute I posted seem identical?
Here it is.... or a Windows tracert!
This tracert also has the last two lines identical. . . .
Send you @Abdullah ping test from Vietnam.
@Not_Oles the test IP belongs to pnap, so not sure how they set it up...
@TigersWay PM'd you the actual server IP..it is 12 hops from here & pings about 26ms.
Is this normal from Thailand to SG or improvements are possible?
@Abdullah You got your answer there...
26ms or 29ms as I got is quite good, I can get up to 41/45 in a lot of cases.
I shared my tracert before, not because of the time, but because of the "going around" part which may be worrying if anyone try to change something!
@Abdullah
Ping from India (BSNL FTTH)
China is worse. I don't live in China so I can't test directly. You may try:
vps9
hostname is available. affbrrIt's BSNL so...
I see 55ms ping from Airtel & ION in Mumbai
Sure bro
Getting a stable < 41 ms from Bangalore on TataSky Broadband.
Nice stuff.
A> @kuroneko23 said:
Confirming here, both private game servers & vpn's are allowed.
Nested virtualization can be enabled, just create a ticket.
@kwaralala
Indeed routing to India seems stable as far I checked with different ISP's
Seems cheap for SG
Pretty good traceroute from Jakarta.
@Abdullah Hi, after clicking checkout & pay, it only shows blank page.
Fixed, please try now.
The server is almost ready, so should be provisioned by tomorrow
