KVM 3 xCoffeelake E2276G 6GB RAM 60GB NVME RAID1 SG??
AbdullahAbdullah Hosting ProviderOG
edited December 2020 in Offers
Hello LES people,
Let's introduce some good Singapore KVM deals before rules kick IN!
As Ant mentioned limits be placed back in sometime (that is still 2 hrs to go) ..
VPS-KVM4G SG Preorder - The popular guy
4GB DDR4 ECC RAM
40GB NVMe SSD RAID1 disk
2vCPU CoffeeLake E2276G @3.7+ Ghz
1 IPv4 + 1TB transfer @ 1Gbps
[Just £15.6 per 3 months recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=309)
VPS-2G Preorder - notitle?
2GB DDR4 ECC RAM
20GB NVMe SSD RAID1 disk
1vCPU CoffeeLake E2276G @3.7+Ghz
1 IPv4 + 500gb transfer @ 1Gbps
[Just £21/year recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=308)
VPS-1G Preorder - The small one
1GB DDR4 ECC RAM
10GB NVMe SSD RAID1 disk
1 IPv4 + 250gb transfer @ 1Gbps
[Just £15.5/year recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=307)
VPS-KVM6G SG Preorder - The mega guy, best value for money
6GB DDR4 ECC RAM
60GB NVMe SSD RAID1 disk
3vCPU CoffeeLake E2276G @3.7+ Ghz
1 IPv4 + 1.5TB transfer @ 1Gbps
[Just £20.3 per 3 months recurring - Singapore - Click here to order](https://my.webhorizon.in/order/config/index/vps/?group_id=12&pricing_id=311)
1. Are these KVM VPS ?
Yes, these are KVM VPS.
  1. What are the OS options?
    We currently have Ubuntu, Debian & CentOS options available in the control panel, custom ISO are installable via ticket.
  2. Is IPv6 enabled?
    IPv6 is not supported on this server right now, however you can always use a IPv6 tunnel broker like HE.
    Plans to implement IPv6 in the near future.
  3. When will these be provisioned?
    These VPS should be provisioned by 6th December, most probably earlier.
  4. A test IP/looking glass?
    IP: 131.153.46.141
    1GB test file
Any other questions? Please ask here or PM is fine too ☺️
All prices are recurring
@AnthonySmith please remove this thread if anything seems wrong.
Regards,
Abdullah
Thanked by (1)Ganonk
  • Just wonder why it's sometimes saying:
    @Abdullah said: E2276G @3.7+ Ghz
    And sometimes:
    @Abdullah said: E2276G @3.8Ghz
    Isn't it the same processor?
    And sometimes:
    A typo sir, it's the same
    Thanked by (1)webcraft
  • TheDPTheDP OGSenpai
    Is this at Hivelocity SG?
    Thanked by (1)Abdullah
    No, at PhoenixNAP SG
  • edited December 2020
    Private game server + VPN allowed?
    Nested virt available?
  • http://ping.pe/131.153.46.141
    More than 200ms from Singapore (Digital Ocean) to Singapore.
    0.  SG 128.199.126.0    Loss%  Snt   Last  Avg   Best  Wrst  StDev AS Name                         PTR
    1.  SG 128.199.127.253  0.0%   20    0.3   0.9   0.2   6.4   1.4   14061 US DIGITALOCEAN           128.199.127.253
    2.  CA 138.197.251.188  0.0%   20    0.9   1.7   0.8   13.9  3.0   -
    3.  CA 138.197.251.185  0.0%   20    0.6   0.5   0.3   1.5   0.3   -
    4.  CA 138.197.245.6    0.0%   20    0.9   2.0   0.7   18.0  4.0   -
    5.  SG 116.51.17.165    0.0%   20    0.9   2.1   0.6   15.9  3.8   2914  US NTT                    ae-2.a00.sngpsi07.sg.bb.gin.nt
    6.  SG 116.51.26.178    0.0%   20    218.8 220.2 211.4 224.8 4.4   2914  US NTT                    xe-0-0-18-2.a00.sngpsi07.sg.ce
    7.  SG 131.153.47.161   0.0%   20    220.9 214.6 204.3 229.3 6.1   59210 SG PHOENIXNAP-SG1         131.153.47.161
    8.     ???              100.0  20    0.0   0.0   0.0   0.0   0.0   -
    9.  SG 131.153.46.141   5.0%   20    227.4 224.8 216.3 230.0 4.3   59210 SG PHOENIXNAP-SG1         131.153.46.141
  • Not for me.
    GCP Singapore VM
    ping -c 5 131.153.46.141
    PING 131.153.46.141 (131.153.46.141) 56(84) bytes of data.
    64 bytes from 131.153.46.141: icmp_seq=1 ttl=52 time=2.12 ms
    64 bytes from 131.153.46.141: icmp_seq=2 ttl=52 time=2.17 ms
    64 bytes from 131.153.46.141: icmp_seq=3 ttl=52 time=2.11 ms
    64 bytes from 131.153.46.141: icmp_seq=4 ttl=52 time=2.14 ms
    64 bytes from 131.153.46.141: icmp_seq=5 ttl=52 time=1.98 ms
    --- 131.153.46.141 ping statistics ---
    5 packets transmitted, 5 received, 0% packet loss, time 9ms
    rtt min/avg/max/mdev = 1.982/2.103/2.170/0.076 ms
    Just for fun, from Sonora, MX :)
    chronos@localhost ~/Downloads $ date -u; ping -c 2 131.153.46.141
    Wed Dec  2 03:59:20 UTC 2020
    64 bytes from 131.153.46.141: icmp_seq=1 ttl=47 time=226 ms
    64 bytes from 131.153.46.141: icmp_seq=2 ttl=47 time=232 ms
    2 packets transmitted, 2 received, 0% packet loss, time 1001ms
    rtt min/avg/max/mdev = 226.220/229.407/232.595/3.223 ms
    chronos@localhost ~/Downloads $ sudo traceroute -I 131.153.46.141
    traceroute to 131.153.46.141 (131.153.46.141), 30 hops max, 60 byte packets
     1  RTK_GW.domain.name (192.168.1.1)  1.098 ms  1.140 ms  1.232 ms
     2  * * *
     3  10.116.60.1 (10.116.60.1)  6.213 ms  6.122 ms  6.021 ms
     4  10.180.51.0 (10.180.51.0)  72.495 ms  72.570 ms  72.503 ms
     5  * * *
     6  * 64.208.239.81 (64.208.239.81)  7.039 ms  6.990 ms
     7  ae0-250G.ar1.DAL1.gblx.net (67.17.95.74)  54.481 ms  54.487 ms  54.470 ms
     8  * * *
     9  * * *
    10  * * *
    11  las-b21-link.telia.net (62.115.123.137)  50.331 ms  50.435 ms *
    12  tky-b1-link.telia.net (62.115.142.129)  164.878 ms  164.891 ms  164.992 ms
    13  * snge-b3-link.telia.net (62.115.123.112)  222.548 ms *
    14  snge-b1-link.telia.net (62.115.124.87)  231.233 ms  231.195 ms  231.777 ms
    15  phoenixnpa-ic-335706-snge-b1.c.telia.net (213.248.81.115)  225.702 ms  225.095 ms  225.015 ms
    16  131.243.172.18 (131.243.172.18)  226.720 ms  232.777 ms  232.890 ms
    17  * * *
    18  131.153.46.141 (131.153.46.141)  226.384 ms  226.369 ms  226.307 ms
    19  131.153.46.141 (131.153.46.141)  226.289 ms  226.270 ms  224.688 ms
  • I wanted to check....
    I usually succeed - from Thailand - to reach any node in SG between 8 to 12 hops..... 131.153.46.141 needs 15!
    Not really sure how important it could be!
    Can you share the ping traceroute?
    Something wrong at gtt, I am looking into it...can you help me with how the ping is from China?
    Can you share the ping ?
    I think you mean to ask @Tigersway to share the traceroute?
    By the way, do you know the reason why lines 18 and 19 (the last two lines) of the traceroute I posted seem identical?
    Here it is.... or a Windows tracert!
      3     5 ms     5 ms     5 ms  10.121.101.246
      4     *        *        *     Request timed out.
      5     6 ms     6 ms     6 ms  10.33.45.1
      6     *        *        *     Request timed out.
      7     7 ms     5 ms     5 ms  mx-ll-110.164.1-168.static.3bb.co.th [110.164.1.168]
      8     6 ms     6 ms     5 ms  mx-ll-110.164.1-107.static.3bb.co.th [110.164.1.107]
      9    30 ms    30 ms    30 ms  mx-ll-110.164.0-103.static.3bb.co.th [110.164.0.103]
     10    31 ms    30 ms    30 ms  ix-xe-0-0-1-2-503.tcore1.svq-singapore.as6453.net [180.87.96.57]
     11    30 ms    30 ms    30 ms  120.29.215.125
     12    30 ms    29 ms    29 ms  131.243.172.18
     13     *        *        *     Request timed out.
     14    30 ms    30 ms    30 ms  131.153.46.141
     15    31 ms    30 ms    30 ms  131.153.46.141
    This tracert also has the last two lines identical. . . .
  • Send you @Abdullah ping test from Vietnam.
    @Not_Oles the test IP belongs to pnap, so not sure how they set it up...
    @TigersWay PM'd you the actual server IP..it is 12 hops from here & pings about 26ms.
    Is this normal from Thailand to SG or improvements are possible? :)
    @Abdullah You got your answer there...
    26ms or 29ms as I got is quite good, I can get up to 41/45 in a lot of cases.
    I shared my tracert before, not because of the time, but because of the "going around" part which may be worrying if anyone try to change something!
  • @Abdullah
    :) It is so happy to see you grow. Now you are providing more and more destinations ;)
  • Ping from India (BSNL FTTH)
    China is worse. I don't live in China so I can't test directly. You may try:
    :s can you PM me a traceroute please,
    It's BSNL so...
    I see 55ms ping from Airtel & ION in Mumbai
    It's BSNL so...
    Sure bro :)
  • Getting a stable < 41 ms from Bangalore on TataSky Broadband.
    Nice stuff.
    Confirming here, both private game servers & vpn's are allowed.
    Nested virtualization can be enabled, just create a ticket. :)
    Thanked by (1)kuroneko23
    @kwaralala
    Indeed routing to India seems stable as far I checked with different ISP's =)
    Seems cheap for SG
  • Pretty good traceroute from Jakarta.
  • @Abdullah Hi, after clicking checkout & pay, it only shows blank page.
    Fixed, please try now.
    The server is almost ready, so should be provisioned by tomorrow =)
