Ordered Polar Bear Storage. Thanks for the credit Servarica
Squats are the new Push-ups
Just note I didnt mention clearly to avoid going out of stock as fast as last time we are limiting 1 order per plan per client
so if you order 2 polar only 1 will be accepted you can order one polar and one flying fish thas fine but not the same plan twice
ServaRica's fast, less than two hours and the machine is finalized.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-07 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 14 Dec 2020 09:55:28 PM EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz CPU cores : 4 @ 2593.770 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 191.0 MiB Disk : 196.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 8.46 MB/s (2.1k) | 24.68 MB/s (385) Write | 8.50 MB/s (2.1k) | 25.21 MB/s (393) Total | 16.96 MB/s (4.2k) | 49.89 MB/s (778) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 24.56 MB/s (47) | 6.00 MB/s (5) Write | 26.25 MB/s (51) | 6.50 MB/s (6) Total | 50.81 MB/s (98) | 12.50 MB/s (11) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 931 Mbits/sec | 933 Mbits/sec Online.net | Paris, FR (10G) | 940 Mbits/sec | 926 Mbits/sec WorldStream | The Netherlands (10G) | 865 Mbits/sec | 926 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 564 Mbits/sec | 36.2 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.01 Gbits/sec | 974 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 996 Mbits/sec | 960 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 964 Mbits/sec | 941 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 471 Mbits/sec | 905 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 446 Multi Core | 1586
The last command throws out a lot of login info from earlier time of March.
last
@servarica_hani Now that you've hopefully got rid of the "extreme torrenters", will the Mouse plans be upgraded to 1GBps at some point?
OK since we managed to have stock for 1 day , I think most people waiting already got their VPS
from now you are allowed to order more than once but max is 3 please
Thanks
The
last
command throws out a lot of login info from earlier time of March.@servarica_hani Now that you've hopefully got rid of the "extreme torrenters", will the Mouse plans be upgraded to 1GBps at some point?
Thanks
