My home rig in the office. Also connected over WiFi bridge to main router (really wish my home had wired ethernet, but so far the bridges work fine). YABS ran using Ubuntu WSL. A bit surprised it completed without a hitch on WSL --
@Mason said:
Storage box in my shed. Recently "downscaled" from a beefy Supermicro server to a desktop to (hopefully) save on some energy costs (2xE5-2670v1's vs 1xi5-10400). Connected over WiFi bridge from garage <--> shed in back yard. 2x480GB SSD drives in SW RAID1 for boot/main disk. 8x8TB HDD drives in SW RAID6 for storage array connected to a RAID controller in passthrough mode.
The CPU performance was 435 in my first test, a few days ago.
Not sure why Clouvider UK connection is slow, and WorldStream NL and Sao Paolo, BR shows as busy.
Latency to my nodes in London and other places seems good, and throughput to London was good for scp.
I did a benchmark on EUserv VS2-free on 2020-11-22 and the CPU was AMD Athlon(tm) II X4 640 Processor.
Today I notice the CPU becomes Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz so I'd run another benchmark.
Note that IPv4 goes through VXLAN so that IPv4 speedtest could be bottlenecked on the dual stack server side (Gullo Germany).
Compared to previous results, the disk is somewhat slower. GeekBench failed last time and was skipped this time since it wouldn't work in 1GB RAM, so that I don't really know the CPU performance.
Basically, that said Friday, they call BF, had the most DEALS, afterwards there was some juicy stuff like that Clouveo but most of time someone tried to shove shit up your arse.
I would like to buy 1 core 1 gb ram 20 gb ssd + 1 tb hdd. PM me if it's possible
Servera Galore 4 GB Plan
(Test unit only, I am not tempted.. I think)
Sat 19 Dec 2020 01:32:01 AM GMT Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 2 @ 3792.870 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 512.0 MiB Disk : 48.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 258.15 MB/s (64.5k) | 3.79 GB/s (59.3k) Write | 258.83 MB/s (64.7k) | 3.81 GB/s (59.6k) Total | 516.98 MB/s (129.2k) | 7.61 GB/s (118.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 7.40 GB/s (14.4k) | 4.70 GB/s (4.5k) Write | 7.79 GB/s (15.2k) | 5.02 GB/s (4.9k) Total | 15.19 GB/s (29.6k) | 9.73 GB/s (9.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 383 Mbits/sec | 268 Mbits/sec Online.net | Paris, FR (10G) | 332 Mbits/sec | 257 Mbits/sec WorldStream | The Netherlands (10G) | 438 Mbits/sec | 599 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 587 Mbits/sec | 267 Mbits/sec Clouvider | NYC, NY, US (10G) | 304 Mbits/sec | 334 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 164 Mbits/sec | 200 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 275 Mbits/sec | 306 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 504 Mbits/sec | 623 Mbits/sec Online.net | Paris, FR (10G) | 528 Mbits/sec | 670 Mbits/sec WorldStream | The Netherlands (10G) | 533 Mbits/sec | 573 Mbits/sec Clouvider | NYC, NY, US (10G) | 549 Mbits/sec | 391 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 642 Mbits/sec | 300 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5777 Multi Core | 10265 Full Test | https://browser.geekbench.com/v4/cpu/15946310 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1301 Multi Core | 2459 Full Test | https://browser.geekbench.com/v5/cpu/5407839blog | exploring visually |
Hosterlabs Solus.io trial, Pro Plus NVMe server:
vps9hostname is available. affbrrServerGalore 1GB
@yoursunny Dedicated ARMv5
The BM immediately above this post is the most awesome YABas result I have seen
KTS24 4 EUR limited
@seriesn NexusBytes 1G Ryzen in London, had this sweet baby since the location opened, just felt like doing a fresh benchmark:
Here's the special 1.5 GB LES exclusive deal from KTS24, @RapToN, in NL:
scp.Nexus Bytes Ryzen Powered NVMe VPS | NYC|Miami|LA|London|Netherlands| Singapore|Tokyo
Virmach
BF special
$15.29 /yr
2 throttled vCPU 2670 v2
2048mb ram
25GB SSD RAID10 with nice IO
1.5TB data @ >1gbps noice
Windows available
Virmach
BF special
$22.82 /yr
2 throttled+weak vCPU 2660
4352mb ram noice
15GB SSD RAID10 with so-so IO
8.5TB data @ >1gbps noice
LAX
Speeed and power....
EUserv VS2-free
Virmach BF2020 $8.88 special
"1 GIGABIT" port gets 2.18 Gbits/sec occasionally.
vps9hostname is available. affbrrAlwyzon
KVM Server S
1vCore, 20GB ssd, 1gbps network, 5TB bandwidth(after this, 10mbps)
6.6€/month(only quartely or annually payment) == 2.20€/month
MVPS.net
VPS One
1vCore, 25GB ssd, 100mbps network, 3TB bandwidth(after this, 1mbps)
€3.00 EUR/monthly
Alwyzon is amazing for the price, but since such new provider, will not switch entirely to it.
@MaxKVM SKVM-1G| 1 CPU AMD EPYC | 1GB ECC RAM| 25GB NVMe | 1TB @ 1Gbps| Amsterdam
Super prem box!
Our Ryzen 2 GB VPS Plan:
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
MaxKVM 6GB.
BuyVM Luxembourg 512MB
LittleCreek LES-1 KVM Double $3.50
Naranja tech, 6c12g240gb @72 eur/yr
https://www.webhosting24.com/cp/cart.php?a=add&pid=458 / https://www.webhosting24.com/cp/cart.php?gid=21
10€/y 1GB KVM
12€/y 1GB BF2020 Alwyzon
6€/y 512MB AMS BF2020 Clouveo
I missed this one. Great value!
But BEHOLD, there is MORE.
4.99€/y 512MB UK BF2020 AlphaVPS
9€/y 1GB AMS BF2020 Naranjatech
12$/y 1GB SEA BF2020 Spartanhost
0.50$/m 1GB LA BF2020 DataIdeas
