Self hosted uptime monitor for tiny yearly vps?
Hey, I have one of those cheap yearly VPSes that's idling and I'd like to turn it into an uptime monitor for my other idling VPSes haha. I was wondering if anyone has a favorite self hosted solution for this? That's also easy on resources or I can limit cpu in a docker container. Thanks
Statping is one I know of; https://github.com/statping/statping
LinuxFreek.com β Hosted on πͺπΊ OVH KS-LE-B - E3 1270v6 - 64GB RAM - 2x 1.2TB NVMe - 500Mbps/1Gbps - GRA (FR)
Nagios is old school but don't people still use it?
https://github.com/phpservermon/phpservermon
I want to make a scenic route monitoring setup with all my boxes:
No hostname available. affbrr
@Neoon's Night-Sky, didn't try it before but it looks good.
We sure do. And Naemon. And Icinga.
Statping, as referenced by Freek already, is really nice. If you are a PHP developer by any chance and are looking to customise your uptime monitor, you might also want to consider Spaties uptime monitor (see also). It's Laravel-based and rather simplistic, but that provides a nice base to add your own features - especially if you are already familiar with the Laravel framework.
Alwyzon - Virtual Servers in Austria starting at 4,49 β¬/month (excl. VAT)
recently there is something like upptime which uses github actions, i like the idea more. the dev is innovative guy
you can give it a try
ThemeForest Profile
Thanks so much for the options, guys! I thought for some reason there would be more options out there or some new up and coming ones.
I did notice the Upptime one that uses github actions but I'm not a fan of github, especially since Microsoft took over. But I think it's a smart serverless solution!
I saw that Statping seemed to be the most popular one and is already included in HomelabOS that I used on one of my servers. Thanks for the PHP option. I have a friend who is a fan of Laravel and I'll send it to him.
Just found this, what do you guys think, anyone tried it? https://github.com/brotandgames/ciao
Statping has multiple checking options. Ciao seems to have only one.
yeah I noticed that. I think I'll go with statping for now. but I like Ciao's ui
