Hetzner AX101 benchmarks and more
I just got my new baby delivered. If it turns out stable, i will move all my own stuff over to this box in the near future. Right now, i will run benchmarks and tests for it. Im starting on Debian 10, and i will do some windows testing later on. I will also order a KVM to look around in the bios. There is a very good chance this is consumer hardware, and a tiny OC might even improve the performance even more. This ofcourse needs alot of testing to make sure it is still stable.
Base spec of the server : Ryzen 5950x cpu, 128gb ddr4 ecc, 1gbit connection, 2 x 3.84TB datacenter nvmes.
If you are looking to order such a server, you now have the chance to post what commands you want to test here first, and i will run them as root.
Ill start with a normal YABS. Note that disks resync is still running, so the disk performance is affected by this. I will rerun once the resyncing is complete. This is due to software raid-1 over the 2 nvmes. I also noticed after running the YABS that the software raid eats quite alot CPU also when resyncing, so this yabs is kinda useless. Ill post it anyway, and update with a new one later.
root@www ~ # curl -sL yabs.sh | bash
Yet-Another-Bench-Script
v2020-12-29
Thu 04 Feb 2021 10:34:41 AM CET
Processor : AMD Ryzen 9 5950X 16-Core Processor
CPU cores : 32 @ 2189.521 MHz
AES-NI : ✔ Enabled
RAM : 125.9 GiB
Swap : 4.0 GiB
Disk : 3.4 TiB
| Block Size | 4k (IOPS) | 64k (IOPS) |
| Read | 418.96 MB/s (104.7k) | 565.31 MB/s (8.8k) |
| Write | 420.06 MB/s (105.0k) | 568.28 MB/s (8.8k) |
| Total | 839.02 MB/s (209.7k) | 1.13 GB/s (17.7k) |
| Block Size | 512k (IOPS) | 1m (IOPS) |
| Read | 624.54 MB/s (1.2k) | 653.22 MB/s (637) |
| Write | 657.72 MB/s (1.2k) | 696.72 MB/s (680) |
| Total | 1.28 GB/s (2.5k) | 1.34 GB/s (1.3k) |
Clouvider | London, UK (10G) | 934 Mbits/sec | 933 Mbits/sec
Online.net | Paris, FR (10G) | 933 Mbits/sec | 931 Mbits/sec
WorldStream | The Netherlands (10G) | 936 Mbits/sec | 937 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | 766 Mbits/sec | 263 Mbits/sec
Clouvider | NYC, NY, US (10G) | 892 Mbits/sec | 422 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 860 Mbits/sec | 442 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 835 Mbits/sec | 349 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy
Clouvider | London, UK (10G) | 919 Mbits/sec | 921 Mbits/sec
Online.net | Paris, FR (10G) | busy | 924 Mbits/sec
WorldStream | The Netherlands (10G) | 920 Mbits/sec | 924 Mbits/sec
Clouvider | NYC, NY, US (10G) | 868 Mbits/sec | 451 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 821 Mbits/sec | 199 Mbits/sec
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1723
Multi Core | 15496
Full Test | https://browser.geekbench.com/v5/cpu/6295440
Quick geekbench 4 : https://browser.geekbench.com/v4/cpu/16026365
Isn't it supposed to be 3.84 TB x 2?
I just posted https://talk.lowendspirit.com/post/quote/2505/Comment_55726 for @willie - could you post your drive details as well?
You Are right. Typo, i am sorry. I will check device info on disks once i get home
Fuck, awesome!
wooooooohooooooooooo
Nice, but why wouldn't it be stable?
Here is the disks in my server : https://www.aliexpress.com/item/1005001290971758.html
Interesting, some specs here:
Kioxia is the new name for Toshiba Memory Systems. Anyway it appears to be a TLC drive though intended for read-intensive workloads. Random write iops = 21k which way below the read iops, and it is PCIe 3.0 rather than 4.0, so not absolutely the latest prem. Still, seems legit. I have no idea what BICS means. More info:
Bics is the name that Western Digital and Toshiba use for their flash nand.
Can you copy and paste smart parameters of this drive ssd?
smartctl -a /dev/nvme1n1
or maybe
nvme smart-log /dev/nvme1n1
If nvme parameters don't have like "ssd life left" then you pretty much have to use it until it dies (regardless of DWPD) because hetzner will refuse to change it.
From Ax101
