Hetzner AX101 benchmarks and more
edited February 2021 in General
I just got my new baby delivered. If it turns out stable, i will move all my own stuff over to this box in the near future. Right now, i will run benchmarks and tests for it. Im starting on Debian 10, and i will do some windows testing later on. I will also order a KVM to look around in the bios. There is a very good chance this is consumer hardware, and a tiny OC might even improve the performance even more. This ofcourse needs alot of testing to make sure it is still stable.
Base spec of the server : Ryzen 5950x cpu, 128gb ddr4 ecc, 1gbit connection, 2 x 3.84TB datacenter nvmes.
If you are looking to order such a server, you now have the chance to post what commands you want to test here first, and i will run them as root.
Ill start with a normal YABS. Note that disks resync is still running, so the disk performance is affected by this. I will rerun once the resyncing is complete. This is due to software raid-1 over the 2 nvmes. I also noticed after running the YABS that the software raid eats quite alot CPU also when resyncing, so this yabs is kinda useless. Ill post it anyway, and update with a new one later.
root@www ~ # curl -sL yabs.sh | bash
Yet-Another-Bench-Script
v2020-12-29
Thu 04 Feb 2021 10:34:41 AM CET
Processor : AMD Ryzen 9 5950X 16-Core Processor
CPU cores : 32 @ 2189.521 MHz
AES-NI : ✔ Enabled
RAM : 125.9 GiB
Swap : 4.0 GiB
Disk : 3.4 TiB
Read 418.96 MB/s (104.7k) 565.31 MB/s (8.8k)
Write 420.06 MB/s (105.0k) 568.28 MB/s (8.8k)
Total 839.02 MB/s (209.7k) 1.13 GB/s (17.7k)
Read 624.54 MB/s (1.2k) 653.22 MB/s (637)
Write 657.72 MB/s (1.2k) 696.72 MB/s (680)
Total 1.28 GB/s (2.5k) 1.34 GB/s (1.3k)
Clouvider | London, UK (10G) | 934 Mbits/sec | 933 Mbits/sec
Online.net | Paris, FR (10G) | 933 Mbits/sec | 931 Mbits/sec
WorldStream | The Netherlands (10G) | 936 Mbits/sec | 937 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | 766 Mbits/sec | 263 Mbits/sec
Clouvider | NYC, NY, US (10G) | 892 Mbits/sec | 422 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 860 Mbits/sec | 442 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 835 Mbits/sec | 349 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy
Clouvider | London, UK (10G) | 919 Mbits/sec | 921 Mbits/sec
Online.net | Paris, FR (10G) | busy | 924 Mbits/sec
WorldStream | The Netherlands (10G) | 920 Mbits/sec | 924 Mbits/sec
Clouvider | NYC, NY, US (10G) | 868 Mbits/sec | 451 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 821 Mbits/sec | 199 Mbits/sec
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1723
Multi Core | 15496
Full Test | https://browser.geekbench.com/v5/cpu/6295440
  • My little hobby site -> www.RaveX.eu
  • @RaveX said: 2 x 2.84TB datacenter nvmes
    Isn't it supposed to be 3.84 TB x 2?
    I just posted https://talk.lowendspirit.com/post/quote/2505/Comment_55726 for @willie - could you post your drive details as well?
  • edited February 2021
    You Are right. Typo, i am sorry. I will check device info on disks once i get home
    Thanked by (1)nullnothere
  • Fuck, awesome!
    wooooooohooooooooooo
  • Nice, but why wouldn't it be stable?
  • @nullnothere said: could you post your drive details as well?
    Here is the disks in my server : https://www.aliexpress.com/item/1005001290971758.html
  • Interesting, some specs here:
    Kioxia is the new name for Toshiba Memory Systems. Anyway it appears to be a TLC drive though intended for read-intensive workloads. Random write iops = 21k which way below the read iops, and it is PCIe 3.0 rather than 4.0, so not absolutely the latest prem. Still, seems legit. I have no idea what BICS means. More info:
  • RazzaRazza OG
    • I have no idea what BICS means. More info:
    Bics is the name that Western Digital and Toshiba use for their flash nand.
    Can you copy and paste smart parameters of this drive ssd?
    smartctl -a /dev/nvme1n1
    or maybe
    nvme smart-log /dev/nvme1n1
    If nvme parameters don't have like "ssd life left" then you pretty much have to use it until it dies (regardless of DWPD) because hetzner will refuse to change it.
    From Ax101
    root@Proxmox-VE ~ # smartctl -a /dev/nvme0n1
    smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.78-2-pve] (local build)
    Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Model Number:                       MTFDHBE3T8TDF
    Serial Number:                      $SERIAL_NUMBER
    Firmware Version:                   95420100
    PCI Vendor/Subsystem ID:            0x1344
    IEEE OUI Identifier:                0x00a075
    Total NVM Capacity:                 3,840,755,982,336 [3.84 TB]
    Unallocated NVM Capacity:           0
    Controller ID:                      1
    Number of Namespaces:               1
    Namespace 1 Size/Capacity:          3,840,755,982,336 [3.84 TB]
    Namespace 1 Formatted LBA Size:     512
    Namespace 1 IEEE EUI-64:            00a075 012b941506
    Local Time is:                      Wed Feb 17 21:49:06 2021 UTC
    Firmware Updates (0x17):            3 Slots, Slot 1 R/O, no Reset required
    Optional Admin Commands (0x001e):   Format Frmw_DL NS_Mngmt Self_Test
    Optional NVM Commands (0x0034):     DS_Mngmt Sav/Sel_Feat Resv
    Maximum Data Transfer Size:         32 Pages
    Warning  Comp. Temp. Threshold:     72 Celsius
    Critical Comp. Temp. Threshold:     75 Celsius
    Namespace 1 Features (0x08):        No_ID_Reuse
    Supported Power States
    St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
     0 +    12.00W       -        -    0  0  0  0        0       0
     1 +    11.00W       -        -    1  1  1  1        0       0
     2 +    10.00W       -        -    2  2  2  2        0       0
     3 +     9.00W       -        -    3  3  3  3        0       0
     4 +     8.00W       -        -    4  4  4  4        0       0
     5 +     7.00W       -        -    5  5  5  5        0       0
     6 +     6.00W       -        -    6  6  6  6        0       0
     7 +     5.00W       -        -    7  7  7  7        0       0
    Supported LBA Sizes (NSID 0x1)
    Id Fmt  Data  Metadt  Rel_Perf
     0 +     512       0         0
     1 -    4096       0         0
     2 -     512       8         0
     3 -    4096       8         0
     4 -    4096      64         0
    === START OF SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    SMART/Health Information (NVMe Log 0x02)
    Critical Warning:                   0x00
    Temperature:                        51 Celsius
    Available Spare:                    100%
    Available Spare Threshold:          5%
    Percentage Used:                    0%
    Data Units Read:                    7,595,137 [3.88 TB]
    Data Units Written:                 707,624 [362 GB]
    Host Read Commands:                 33,856,435
    Host Write Commands:                10,999,788
    Controller Busy Time:               2,555
    Power Cycles:                       7
    Power On Hours:                     214
    Unsafe Shutdowns:                   0
    Media and Data Integrity Errors:    0
    Error Information Log Entries:      0
    Warning  Comp. Temperature Time:    0
    Critical Comp. Temperature Time:    0
    Temperature Sensor 1:               60 Celsius
    Temperature Sensor 2:               53 Celsius
    Error Information (NVMe Log 0x01, max 63 entries)
    No Errors Logged
    root@Proxmox-VE ~ #
