Raspberry Pi Pico released and available at $4 only - I kind of want 10
2»
  • I have on sat on my desk but unsure what to do with it.....
    Then again I also have a box of 200+ model B’s that I need a plan for....
    Thanked by (2)cybertech Chronic
  • vyasvyas OGSenpai
    @vyas said:
    @cybertech
    @Ympker also has a Pi4, as do I. Problem with the 4 GB RAM model is heating. I suppose the issue will be bigger with 8 GB model.
    Ympker did not have that problem because of his location.
    Depending on where you live, you may or may not be happier with a 4 GB
    Thinking of getting one of the two below:
    www.amazon.in/Raspberry-Model-Aluminum-Cooling-Metal/dp/B08D9Q76G5
    https://www.amazon.in/REES52-Raspberry-Armor-Aluminium-Heatsink/dp/B07X5XXKTZ
    Reading the reviews now. Concerned about noise levels from the latter.
  • @jamesmd said: Then again I also have a box of 200+ model B’s that I need a plan for....
    Good lord why do you have that many!
    Thanked by (2)Amitz Chronic
    Well I had a few beers then I went on eBay. Never ends well!
    Thanked by (2)Amitz Dream
    Build a high performance cluster? :#
    I’d love too but I have another plan: https://blog.jmdawson.co.uk/i-bought-200-raspberry-pi-model-bs-and-im-going-to-fix-them-part-1/
    Thanked by (2)flips atth
    Reading that I just realised who you are :) keeping busy?
  • Haha yes very! How about yourself?
  • edited January 2021
    Yeah same and then there is this place on top!
    Great to see this place doing well! I remember when you were first talking about starting it.
  • @jamesmd those are pi model 1B's? How do you plan to fix them? Do any work? They have full sized hdmi output right? I might be interested in buying one or two, if you're in the US (not sure). Purpose is to make a TV typewriter for my mom's TV as she is hearing impaired.
  • This one is not strictly a SBC because of the removable DIMMs but I found this project interesting:
    https://www.udoo.org/udooboltgear/
    Technical Specs:
    Processor:
    * CPU AMD Ryzen™ Embedded V1605B SoC up to 3.6 GHz
    GPU:
    * AMD Radeon™ Vega 8 Graphics - 8 GPU Compute Units
    RAM:
    * 2x SO-DIMM Dual-channel 64-bit DDR4 2400 MT/s with ECC support up to 32GB
    Microchip ATmega32U4 8-bit AVR RISC-based microcontroller.
    Video interfaces:
    * 2x HDMI 1.4/2.0a
    * 2x USB Type-C (DP alternate mode)
    Storage:
    * 1x M.2 Socket 2 Key B 2242/2260 for SSD SATA modules (featured also PCI-e x2)
    * 1x M.2 Socket 3 Key M 2280 for NVMe modules (PCI-e x4 Gen 3 interface)
    * 1x SATA III 6Gbit/s standard connector
    Networking:
    * 1x Gigabit Ethernet LAN interface
    * 1x M.2 Key E slot for optional Wireless (WiFi+BT) Combo module
    Audio interfaces:
    * HD Audio Codec Realtek ALC888S
    * Microphone + Headphone Combo Connector (TRRS)
    * Pre-amplified stereo Speaker Connectors (up to 3W)
    * Digital Optical audio S/PDIF and analog stereo output combo jack 3.5mm connector
    2x USB 3.0 type-A sockets
    2x USB Type-C :
    * USB 3.1
    * DisplayPort Alternate Mode
    * Dual Role Port (DRP) USB Power Delivery (USB-PD) 3.0
    Embedded Controller I/O :
    * 2x UART ports**
    * 2x I2C interface**
    * 1x SPI interface**
    * 1x FAN Controller**
    * up to 10x GPIO**
    Power In:
    * 19V DC Power Jack min 3.15A (60W) for basic functionalities - Male connector 4.5mm x 3.0mm with pin inside.
    * 2x USB Type-C power in. PD sink profile 20V/3A(60W).
    RTC Battery Connector + RTC Coin Battery
    * Bi-color Power Status LED
    Arduino™ Leonardo-Compatible I/O :
    * 12x analog inputs**
    * up to 23x digital input/output (7 PWM)**
    * 1x UART 1x I2C 1x SPI**
    * 3x Grove connectors:
    * 1x ANALOG INPUT, 1x UART or DIGITAL I/O, 1x I2C or DIGITAL I/O
    Dimensions: 12cm x 12cm - 4.72” x 4.72”
    **Available on Pin Headers
    https://www.udoo.org/docs-gear/Introduction/Introduction.html
  • That's a compact re ryzen box on special for $400. Nice alternative to a Mac mini or NUC but not in anything like the sbc space.
  • @beagle said: This one is not strictly a SBC because of the removable DIMMs but I found this project interesting:
    Technical Specs:
    oh wow, I really like that.
    Thanked by (1)beagle
  • I find this a lot more interesting:
    https://www.clockworkpi.com/devterm
  • if i want to use pi for only pi-hole, which product do you recommend?
    https://www.pishop.us/product/raspberry-pi-zero/
    also those who used both pi-hole and adguard....which one do you think is better?
    thanks.
    any speculation how soon RPI 5 will be coming and what specs?
    Pico...I'd rather get the version with wifi Arduino Nano RP2040 Connect Board
    Still a fair time out last I checked
    Thanked by (1)cybertech
    I'm hoping at least for an Rpi 800
    edited February 2021
    @jamesmd The blogs were interesting until I came across this:
    "I was unable to continue the repairs on the boards with failed Ethernet due to waiting on solder wick to arrive however I found some in a draw! "
    What a lucky draw? Grr. The word is drawer. Which accent drops the "er"?
    Sorry, just one of my many pet peeves, frequently seen on feeBay, along with lense.
    Still read to the end of Part 3, 'cos clever folks can't all speak proper. :p
    Arduino idle program:
    void setup()
    void loop()
    No hostname available. affbrr
