@sgheghele said:
I am pleasantly surprised by how well these NAT VPSs perform in first tests! Still have to find a good use case for them, but for the price I couldn't let these idlers escape.
@fragpic said: @Abdullah Thanks for the quick provisioning.
Also, passwords in plaintext is a big no no. Please don't save unencrypted passwords anywhere.
Hey, did you get it solved?
I think you will need to restart the vps after enabling fuse
@Abdullah
i tried refresh it by reinstall, reenabled the options in panel, reboot, but got another error mount helper error: fusermount: fuse device not found, try 'modprobe fuse' first Fatal error: failed to mount FUSE fs: fusermount: exit status 1 root@ubuntu:~# modprobe fuse modprobe: FATAL: Module fuse not found in directory /lib/modules/3.10.0-1127.18.2.vz7.163.46
please create a ticket, so can look into your issue.
Having the same issue. Fuse is installed but the module is missing. Using Ubuntu 20.04 with the provided template.
@Abdullah
I have bought your VPS just while ago, but I have small issue. I have installed OpenVPN, it installed successfully, but the problem is openvpn app is connecting to it but internet not working afterwwards. Any solution please ??
Hi,
Can you access internet from inside the VPS (like try ping 1.1.1.1 from terminal)?
Just reinstall the OS & use this openvpn install script https://github.com/Nyr/openvpn-install enter one of your assigned ports when asked.
This script should work, as it always does.
Hi,
Let me know.
Hi, Abdullah
I am installing from the same script that you mentioned above, when it is asking for IP address I am putting my IPV4 address, then port no: 18020 (my internal IP is eding with 180). for DNS I am using Google, UDP.. That how I am installing.
Pining is working fine even after installing OpenVPN on VPS
Hi,
Let me know.
Hi, Abdullah
Has anyone been able to get wireguard working on their VPS?
I've been trying but it doesn't seem to work and I think it is because there is no UDP port forwarding support on them, since I only see the TCP option when using the Domain Forwarding setting. @Abdullah
Am I doing something wrong or is this expected behavior?
I'm guessing that is India location, (using a different approach there - Domain Forwarding)
UDP ports need to be forwarded manually, by creating a ticket.
@Abdullah said: I'm guessing that is India location, (using a different approach there - Domain Forwarding) UDP ports need to be forwarded manually, by creating a ticket.
I have 2 NAT VPS working on NL and SG locations
Had used @Nyr scripts on them . No issues faced
Yes. Raising a ticket now.
I have replied your ticket. On these NAT VPS, ports are assigned according to the internal IP. I hope that works
Any issues in network
VPS has gone down 4 times in last 40 minutes for 11 minutes
Any maintenance ?
Edit - Only ipv6 went down not NAT ipv4
My order is #603fabfd1c882, Thanks @Abdullah !
Ordered.
I feel the same way
Is there a script to debloat the base template?
I know there is one to convert it to alpine but I don't want to switch from ubuntu.
My usual, for Debian 10:
You'll need some changes for Ubuntu.
yea, I need to correct that, Noted.
https://webhorizon.net
Technically he asked whether Adguard would run with the default ports ... which it likely will quite happily ( it just won't work on ipv4 ).
I think Miami is gone.
F
MIA is MIA.
@Abdullah Bit the bullet , again and ....again
Miami is back
OP had Miami link broken all the time!, didn't realize until now.
@kuduku welcome!
A unrelated meme I came across internet ( @seriesn style ?)
Memes are life ?
Replied your ticket.
Hi Abdullah,
Is it possible to do domain forwarding on port 853(DoT)?
Hi,
ping 1.1.1.1from terminal)?Just reinstall the OS & use this openvpn install script https://github.com/Nyr/openvpn-install enter one of your assigned ports when asked.
Let me know.
@Abdullah give him the fast internet man.
Better yet use WireGuard
Probably port not open or using the wrong port?
Hi, Abdullah
PM'd you, please make a ticket.
@Abdullah
Any maintenance ?
