[Clearance Sale] NAT VPS at COST + 5 x 256MB NAT VPS Bundle @ $15 !!
2
  • My order is #603fabfd1c882, Thanks @Abdullah !
    Thanked by (1)Abdullah
  • Ordered.
  • @sgheghele said:
    I am pleasantly surprised by how well these NAT VPSs perform in first tests! Still have to find a good use case for them, but for the price I couldn't let these idlers escape.
    I feel the same way :)
  • Is there a script to debloat the base template?
    I know there is one to convert it to alpine but I don't want to switch from ubuntu.
    My usual, for Debian 10:
    echo 'APT::Install-Recommends "no";
    APT::Install-Suggests "no";' >/etc/apt/apt.conf.d/80recommends
    echo deb http://deb.debian.org/debian buster-backports main >/etc/apt/sources.list.d/buster-backports.list
    apt-mark auto $(apt-mark showmanual)
    apt update
    apt install bind9-host curl git htop initramfs-tools iptables iputils-ping jq locales net-tools openssh-server patch resolvconf screen software-properties-common sudo systemd-sysv tcpdump telnet traceroute vim wget zip
    apt autoremove --purge
    apt full-upgrade
    You'll need some changes for Ubuntu.
    No hostname left!
  • @Abdullah Thanks for the quick provisioning.
    Also, passwords in plaintext is a big no no. Please don't save unencrypted passwords anywhere.
    yea, I need to correct that, Noted.
  • skorousskorous OGSenpai
    @Aaron said:
    Unfortunately no.
    Technically he asked whether Adguard would run with the default ports ... which it likely will quite happily ( it just won't work on ipv4 ).
    Thanked by (2)AaronSS Abdullah
  • I think Miami is gone.
    F
    MIA is MIA.
    Thanked by (3)vyas Abdullah Ouji
    No hostname left!
  • @Abdullah Bit the bullet , again and ....again
    edited March 2021
    F
    Miami is back
    OP had Miami link broken all the time!, didn't realize until now.
    @kuduku welcome!
    A unrelated meme I came across internet ( @seriesn style ?)
    Thanked by (1)kuduku
  • @Abdullah said:
    please create a ticket, so can look into your issue.
    Having the same issue. Fuse is installed but the module is missing. Using Ubuntu 20.04 with the provided template.
    Replied your ticket. :)
    Thanked by (1)sgheghele
  • Hi Abdullah,
    I have bought your VPS just while ago, but I have small issue. I have installed OpenVPN, it installed successfully, but the problem is openvpn app is connecting to it but internet not working afterwwards. Any solution please ??
  • @Abdullah said:
    No, can't run a public adguard instance bcz. DNS port 53 is blocked. But a wayaround you can configure DNS-over-https, that should work. :)
    Can also use a wireguard+adguard setup
    Is it possible to do domain forwarding on port 853(DoT)?
    @abskillz said:
    Hi Abdullah,
    Hi,
    Can you access internet from inside the VPS (like try ping 1.1.1.1 from terminal)?
    Just reinstall the OS & use this openvpn install script https://github.com/Nyr/openvpn-install enter one of your assigned ports when asked.
    This script should work, as it always does. :)
    Let me know. :)
  • @Abdullah give him the fast internet man.
  • Better yet use WireGuard :)
  • @abskillz said:
    Hi Abdullah,
    Probably port not open or using the wrong port?
  • @Abdullah said:
    Hi,
    Let me know. :)
    Hi, Abdullah
    I am installing from the same script that you mentioned above, when it is asking for IP address I am putting my IPV4 address, then port no: 18020 (my internal IP is eding with 180). for DNS I am using Google, UDP.. That how I am installing.
    Pining is working fine even after installing OpenVPN on VPS
    @abskillz said:
    Hi, Abdullah
    PM'd you, please make a ticket.
  • Has anyone been able to get wireguard working on their VPS?
    I've been trying but it doesn't seem to work and I think it is because there is no UDP port forwarding support on them, since I only see the TCP option when using the Domain Forwarding setting.
    @Abdullah
    Am I doing something wrong or is this expected behavior?
    @Abdullah
    I'm guessing that is India location, (using a different approach there - Domain Forwarding)
    UDP ports need to be forwarded manually, by creating a ticket.
  • fragpicfragpic OG
    edited March 2021
    @Abdullah said: I'm guessing that is India location, (using a different approach there - Domain Forwarding) UDP ports need to be forwarded manually, by creating a ticket.
    Yes. Raising a ticket now.
    @Abdullah
    I have 2 NAT VPS working on NL and SG locations
    Had used @Nyr scripts on them . No issues faced
    I have replied your ticket. On these NAT VPS, ports are assigned according to the internal IP. I hope that works :)
  • edited March 2021
    Any issues in network
    VPS has gone down 4 times in last 40 minutes for 11 minutes
    Any maintenance ?
    Edit - Only ipv6 went down not NAT ipv4
