Wireguard-go on NAT VPS
Hey there,
I just wanted to make use of my idling NAT VPS and tried to install Wireguard-go.
It worked just fine, however there seem to be some issues getting iptables to work.
I've already switched to iptables-legacy but I'm still getting this error message:
iptables v1.8.2 (legacy): can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
ip6tables v1.8.2 (legacy): can't initialize ip6tables table `nat': Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
Provider: Gullo and Inceptionhosting
Use @Nyr script
https://github.com/Nyr/wireguard-install
It sets up everything perfectly
https://clients.inceptionhosting.com/index.php?rp=/knowledgebase/36/Iptables-csf-ufw-firewalld-or-vpn-software-problems.html try refer to this KB.
