WARNING look at disk speeds(slow for NVME), and variable internet speed. Sadly for me that's a deal breaker and I requested a refund sorry ApeWeb (maybe i will come back when I will need more resources). Btw they provide price excluding VAT, so beware. Above your post I posted yabs, and think if it's worth it.
Edit: I will reconsider ordering via a friend from the USA, so as not to pay VAT
I would note that not too long ago, vpses were doing good with SSD 10K IOPS on 4K, so yeah not a Biggie to me if the results aren't as high performing as some other providers show.
if provider is limiting the IOPS per VM, it should (I think?) do well with multi tenants. but if this result isn't due to rate limit, and if it's a RAID 1 or worse, then hmmm.
If this improves imma order via a friend that lives in the USA
Inode capped at 80k
Disk io is not restricted. Looks like you have hit it at an unfortunate time when it was under load as those are lower results than I would have expected (although should still be perfectly usable). I would have offered to transfer you to a different node.
Inode capped at 80k
Dude I'm getting those results (even at better time) on my Contabo VPS with NORMAL ssd in raid 10. Those in my opinion are not normal speeds for nvme
Btw look at tickets, and refound me imma order via a friend that lives outside of eu to avoid vat
Inode capped at 80k
Inode capped at 80k
To be fair i also had raised the same issue of network and speeds and then refunded
I also had same disk speeds as YABS in the thread
Same here. I'm somewhat surprised about the negative feedback. The benchmarks posted above look much better than many boxes I have with other providers which still do a great job.
@codelock said:
Unmetered bandwidth ?
Wondering what is the cheapest plan you can do with 60 mbps all day / night traffic allowed ?
Minimum 10 gb disk.
Minimum 10 gb disk.
Minimum 10 gb disk.
Can I order this custom package as well? or just for skorupion?
Contact me at: +1 (509) 606-3569 or [email protected]
Seems he edited the description, and if it was exclusive then he would dm me the offer. BEWARE look YABS oh and if from eu add vat on top
Giving your VPS a second chanse at showing its disk speeds:
Real NVME:
Your NMVE(?):
Inode capped at 80k
here's mine now
This server is in raid 6.
£6pm
£7.50pm
Check your ticket it has already been replied to.
Done thx
My server with them has been solid. Is it worth requesting yours to be moved to a different server?
Minimum 10 gb disk.
maybe something can be tweaked for the disk settings. DD is good.
Do you need ipv4?
Yes
(Can be nat ipv4, with 20 ports forwaded)
70mbps Unmetered, 10gb nvme, 512mb memory, 1x ipv4 1x /112 ipv6. £6pm.
@ApeWeb can you pls check website is offline . I had PMed you yesterday but you have not replied
The website is back up. We were experiencing a layer 7 denial of service attack on it but this has been mitigated now.
ok thanks
Any News about your Moldova location ?
