Share your most valued AMD EPYC/RYZEN VPS / Dedicated
This is the AMD powerhouse, show us what you got.
Was lucky to grab one of this during BF from AlphaVPS:
4 vCPU
3GB DDR4
45GB NVMe
3TB @ 1gbps
LAX
EUR 45/year
Performance has been smashing since half a year now.
load is either very well managed or I'm on a friendly node.
[root@cybertech ~]# curl -sL yabs.sh | bash -s -- -4 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-29 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun May 2 12:29:08 +08 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 4 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 2.9 GiB Swap : 64.0 MiB Disk : 44.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 329.66 MB/s (82.4k) | 1.22 GB/s (19.2k) Write | 330.53 MB/s (82.6k) | 1.23 GB/s (19.3k) Total | 660.20 MB/s (165.0k) | 2.46 GB/s (38.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.37 GB/s (2.6k) | 1.36 GB/s (1.3k) Write | 1.44 GB/s (2.8k) | 1.45 GB/s (1.4k) Total | 2.82 GB/s (5.5k) | 2.81 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 840 Mbits/sec | 839 Mbits/sec Online.net | Paris, FR (10G) | 821 Mbits/sec | 790 Mbits/sec WorldStream | The Netherlands (10G) | 814 Mbits/sec | 845 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 735 Mbits/sec | 253 Mbits/sec Clouvider | NYC, NY, US (10G) | 903 Mbits/sec | 903 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 887 Mbits/sec | 877 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 931 Mbits/sec | 934 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 789 Mbits/sec | 633 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5236 Multi Core | 14844 Full Test | https://browser.geekbench.com/v4/cpu/16151746
---------------------------------------------------------------------- CPU Model : AMD Ryzen 9 3900X 12-Core Processor CPU Cores : 4 CPU Frequency : 3792.874 MHz CPU Cache : 512 KB Total Disk : 45.0 GB (8.2 GB Used) Total Mem : 2985 MB (544 MB Used) Total Swap : 63 MB (63 MB Used) System uptime : 14 days, 2 hour 34 min Load average : 0.32, 0.46, 0.23 OS : CentOS Linux release 8.3.2011 Arch : x86_64 (64 Bit) Kernel : 5.11.15-1.el8.elrepo.x86_64 TCP CC : bbr Virtualization : KVM Organization : AS18450 WebNX, Inc. Location : Los Angeles / US Region : California ---------------------------------------------------------------------- I/O Speed(1st run) : 2.3 GB/s I/O Speed(2nd run) : 2.4 GB/s I/O Speed(3rd run) : 2.3 GB/s Average I/O speed : 2389.3 MB/s ---------------------------------------------------------------------- Node Name Upload Speed Download Speed Latency Speedtest.net 840.97 Mbps 670.65 Mbps 1.45 ms Beijing CU 549.21 Mbps 636.42 Mbps 144.57 ms Shanghai CT 195.39 Mbps 921.24 Mbps 253.01 ms Shanghai CU 521.37 Mbps 953.25 Mbps 147.88 ms Guangzhou CT 311.48 Mbps 935.65 Mbps 258.04 ms Shenzhen CU 416.59 Mbps 935.27 Mbps 180.74 ms Hongkong CN 418.04 Mbps 920.93 Mbps 177.65 ms Singapore SG 437.02 Mbps 869.67 Mbps 166.07 ms Tokyo JP 213.20 Mbps 5.60 Mbps 114.81 ms ---------------------------------------------------------------------
Ryzen dedi bench alllowed?
of course! would be even better edited topic to include dedicated
Too bad it is running Windows and WSL doesn't want to run yabs
I was very lucky to get a Ryzen VPS from @DataIdeas during Black Friday. Their site was basically dead when it got posted. Will post a yabs later.
I believe the specs were:
Ryzen 9 3900X (1 vCore)
1GB Memory
10GB SSD Storage
1 IPv4 & 1 IPv6
Unmetered BW
$0.50/month (billed monthly)
Also got a nice Ryzen VPS from Nexril.
Ryzen 9 3950X (1 vCore)
1GB Memory
15GB SSD Storage
1 IPv4 & /64 IPv6
1TB Transfer
$1/month (billed yearly)
Both pretty solid, I used to run a website on the first one, but now it's just idling because I ended up having to move the website over to another VPS since it got popular. Both have been pretty solid so far, although DataIdeas has had some downtime lately.
I was lucky to got the following one from NaranjaTech
4 vCPU EPYC 7452
8GB DDR4
120GB NVMe
20TB @ 1gbps
AMS
EUR 80/year
Performance is solid becaue of no steal and good IO, and I can use up to 50% CPU on average:
wuuuuuut.....
Hi @cybertech
Hetzner AX101 Ryzen 9 5950X bare metal
There was a thread about Slackware on HN a couple of days ago. The original HN poster mentioned in a comment that in the Slackware changelog for April 12 and February 15, Patrick Volkerding had referred to a beta for Slackware 15. So I had to go grab Slackware current and install it inside a KVM. I will set up IPv6 too, of course.
Slackware seems to have a minimal KVM virtualization penalty on Geekbench 5: Single Core score 1687 vs. 1661 on bare metal. I've seen the bare metal higher, 1673, 1719, and 1725.
Okay, here is the Slackware KVM with IPv6 now enabled:
Your IO are exceptionally good
@Mason Do you mind making yabs for Windows ? I hope you would love to do that
Last I tried, it worked perfectly fine using WIndows Subsystem Linux, beyond that I probably won't pursue Windows compatibility.
Well probably it just doesnt work for me lol
here's mine on naranjatech too. top stuff.
EPYC 1 vCore
2GB Ram
30GB NVMe Disk
5TB BW
20 €/year (+vat if applicable)
@valkyrie WSL 1 or 2?
WSL 2 and it should really run as I ran one on my test rig at home and it ran fine, maybe a buggy installation I guess
