Post some YABS bench here
12122242627136
  • _MS__MS_ OGSenpai
    Scaleway STARDUST1-S (IPv6-only) Amsterdam - €0.37/m
    #                     v2021-05-28                    #
    Wed Jun  2 13:28:10 UTC 2021
    Processor  : AMD EPYC 7281 16-Core Processor
    CPU cores  : 1 @ 2096.056 MHz
    RAM        : 973.2 MiB
    Swap       : 0.0 KiB
    Disk       : 9.1 GiB
    Read       | 153.57 MB/s  (38.3k) | 1.03 GB/s    (16.1k)
    Write      | 153.97 MB/s  (38.4k) | 1.03 GB/s    (16.2k)
    Total      | 307.54 MB/s  (76.8k) | 2.06 GB/s    (32.3k)
    Read       | 1.41 GB/s     (2.7k) | 1.51 GB/s     (1.4k)
    Write      | 1.48 GB/s     (2.9k) | 1.61 GB/s     (1.5k)
    Total      | 2.89 GB/s     (5.6k) | 3.12 GB/s     (3.0k)
    Clouvider       | London, UK (10G)          | 359 Mbits/sec   | 5.25 Gbits/sec
    Online.net      | Paris, FR (10G)           | 352 Mbits/sec   | 5.49 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 222 Mbits/sec   | 5.37 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 210 Mbits/sec   | 1.80 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 237 Mbits/sec   | 843 Mbits/sec
    Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    Thanked by (1)cybertech
  • NeoonNeoon OGSenpai
    @Mason said:
    Coming soon to a repo near you
    I have to clean it up a bit first and take it through a few more test runs, then it should be good to go.
    hmmm, you could add a experimental repo, could you right?
    Thanked by (2)seriesn Falzo
    #                     v2021-05-28                    #
    RAM        : 973.2 MiB
    Swap       : 0.0 KiB
    Disk       : 9.1 GiB
    stardust configuration is fixed, i.e. no additional ram/CPU?
  • _MS__MS_ OGSenpai
    edited June 2021
    Yes. Stardust instances come in only one configuration. If you need more resources, you have to upgrade to their "DEV" instances. STARDUST1-S is like their DEV1-XS instance.
    They say that each account can have a total of two Stardust instances, one each at their PAR1 and AMS1 regions.
    It won't be wrong to say that this is their way of increasing signups (by offering cheapest entry-level VPS among major players). Hoping that some would upgrade to more costly DEV instances and/or use their other services.
  • _MS__MS_ OGSenpai
    edited June 2021
    Scaleway STARDUST1-S (IPv6-only) Paris - €0.37/m
    #                     v2021-05-28                    #
    Thu Jun  3 17:01:40 UTC 2021
    CPU cores  : 1 @ 2096.060 MHz
    RAM        : 973.2 MiB
    Swap       : 0.0 KiB
    Disk       : 9.1 GiB
    Read       | 135.55 MB/s  (33.8k) | 987.55 MB/s  (15.4k)
    Write      | 135.90 MB/s  (33.9k) | 992.75 MB/s  (15.5k)
    Total      | 271.45 MB/s  (67.8k) | 1.98 GB/s    (30.9k)
    Read       | 1.32 GB/s     (2.5k) | 1.32 GB/s     (1.2k)
    Write      | 1.39 GB/s     (2.7k) | 1.41 GB/s     (1.3k)
    Total      | 2.71 GB/s     (5.2k) | 2.73 GB/s     (2.6k)
    Clouvider       | London, UK (10G)          | 359 Mbits/sec   | 4.91 Gbits/sec
    Online.net      | Paris, FR (10G)           | 350 Mbits/sec   | 5.25 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 200 Mbits/sec   | 5.41 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 213 Mbits/sec   | 1.96 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 238 Mbits/sec   | 1.03 Gbits/sec
    Depends, for some it says 2, for me it says 1.
    It even says, a location is out of stock, which is the worst fake news I have ever seen.
    You just grab the cli, and deploy via that, worked for me, while FR was out of stock.
  • MasonMason AdministratorOG
    edited June 2021
    @Neoon said:
    Will put the aarch64 stuff in there tonight. Armv7/aarch32 will come later
    Scratch that, not happening tonight.
  • FalzoFalzo Senpai
    edited June 2021
    @Mason said: Faith
    Thanked by (2)Mason cybertech
  • _MS__MS_ OGSenpai
    edited June 2021
    I think it shows the same to everyone. It showed me 1/1 and 100% used when I only had 1 instance. But, did not stop me from creating another instance on a different location. Now, it's 2/1. ¯_(ツ)_/¯
    rules are meant to be broken.
    Thanked by (1)_MS_
    @Neoon said:
    Had to take an impromptu trip to the hospital last night (everything's fine). Should have time to get it sorted out tonight after work.
    No worries, you shall not take my gifs to seriously.
    But you can make it up to me (wink wink)
    Thanked by (1)ehab
    @Neoon - ARM support added to the YABS repo, please test and let me know if you hit any issues. I've only been able to test on a Raspberry Pi 3B that I have, so I'm anticipating some unforeseen issues arising. Thanks!
    #                     v2021-06-05                    #
    Sat Jun  5 06:43:45 UTC 2021
    ARM-compatibility is considered *experimental*
    Processor  : Cortex-A53
    CPU cores  : 4 @ 1200.0000 MHz
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 908.2 MiB
    Swap       : 1024.0 MiB
    Disk       : 14.6 GiB
    Read       | 425.00 KB/s    (106) | 3.73 MB/s       (58)
    Write      | 447.00 KB/s    (111) | 4.00 MB/s       (62)
    Total      | 872.00 KB/s    (217) | 7.74 MB/s      (120)
    Read       | 5.63 MB/s       (11) | 5.25 MB/s        (5)
    Write      | 6.25 MB/s       (12) | 5.71 MB/s        (5)
    Total      | 11.88 MB/s      (23) | 10.96 MB/s      (10)
    Clouvider       | London, UK (10G)          | 91.9 Mbits/sec  | 92.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 91.1 Mbits/sec  | 92.2 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 93.2 Mbits/sec  | 94.1 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 98
    Multi Core      | 282
    Full Test       | https://browser.geekbench.com/v5/cpu/8263881
  • edited June 2021
    Finally managed to open an Oracle Cloud account - let it rip!
    Oracle Cloud, VM.Standard.A1.Flex, Balanced HDD, Ubuntu 20.04 @ San Jose
    #                     v2021-06-05                    #
    Sat Jun  5 07:32:15 UTC 2021
    Processor  : Neoverse-N1
    CPU cores  : 16
    NUMA node0 0-15 @  MHz
    RAM        : 15.5 GiB
    Swap       : 0.0 KiB
    Disk       : 45.1 GiB
    Read       | 6.35 MB/s     (1.5k) | 26.69 MB/s     (417)
    Write      | 6.35 MB/s     (1.5k) | 27.49 MB/s     (429)
    Total      | 12.70 MB/s    (3.1k) | 54.19 MB/s     (846)
    Read       | 24.36 MB/s      (47) | 24.06 MB/s      (23)
    Write      | 26.44 MB/s      (51) | 26.84 MB/s      (26)
    Total      | 50.81 MB/s      (98) | 50.90 MB/s      (49)
    Clouvider       | London, UK (10G)          | 504 Mbits/sec   | 590 Mbits/sec
    Online.net      | Paris, FR (10G)           | 466 Mbits/sec   | 650 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 512 Mbits/sec   | 619 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 357 Mbits/sec   | 43.0 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.05 Gbits/sec  | 1.28 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 620 Mbits/sec   | 1.24 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.02 Gbits/sec  | 2.02 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 185 Mbits/sec   | 404 Mbits/sec
    Single Core     | 828
    Multi Core      | 9506
    Full Test       | https://browser.geekbench.com/v5/cpu/8264282
    Oracle Cloud, VM.Standard2.2, Balanced HDD, Ubuntu 20.04 @ San Jose
    #                     v2021-06-05                    #
    Sat Jun  5 07:44:32 UTC 2021
    Processor  : Intel(R) Xeon(R) Platinum 8167M CPU @ 2.00GHz
    CPU cores  : 4 @ 1995.312 MHz
    RAM        : 29.4 GiB
    Swap       : 0.0 KiB
    Disk       : 45.1 GiB
    Read       | 6.33 MB/s     (1.5k) | 26.36 MB/s     (411)
    Write      | 6.33 MB/s     (1.5k) | 26.85 MB/s     (419)
    Total      | 12.66 MB/s    (3.1k) | 53.22 MB/s     (830)
    Read       | 24.59 MB/s      (48) | 24.10 MB/s      (23)
    Write      | 26.11 MB/s      (51) | 26.61 MB/s      (25)
    Total      | 50.70 MB/s      (99) | 50.71 MB/s      (48)
    Clouvider       | London, UK (10G)          | 894 Mbits/sec   | 324 Mbits/sec
    Online.net      | Paris, FR (10G)           | 906 Mbits/sec   | 331 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 897 Mbits/sec   | 309 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 791 Mbits/sec   | 71.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 950 Mbits/sec   | 438 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 943 Mbits/sec   | 435 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.01 Gbits/sec  | 1.01 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 269 Mbits/sec   | 440 Mbits/sec
    Single Core     | 447
    Multi Core      | 973
    Full Test       | https://browser.geekbench.com/v5/cpu/8264436
    Oracle Cloud, VM.Standard.E2.2, Balanced HDD, Ubuntu 20.04 @ San Jose
    #                     v2021-06-05                    #
    Sat Jun  5 07:57:47 UTC 2021
    Processor  : AMD EPYC 7551 32-Core Processor
    CPU cores  : 4 @ 1996.249 MHz
    RAM        : 15.6 GiB
    Swap       : 0.0 KiB
    Disk       : 45.1 GiB
    Read       | 6.33 MB/s     (1.5k) | 26.26 MB/s     (410)
    Write      | 6.34 MB/s     (1.5k) | 26.74 MB/s     (417)
    Total      | 12.67 MB/s    (3.1k) | 53.00 MB/s     (827)
    Read       | 24.67 MB/s      (48) | 24.07 MB/s      (23)
    Write      | 26.03 MB/s      (50) | 26.57 MB/s      (25)
    Total      | 50.71 MB/s      (98) | 50.64 MB/s      (48)
    Clouvider       | London, UK (10G)          | 903 Mbits/sec   | 249 Mbits/sec
    Online.net      | Paris, FR (10G)           | 917 Mbits/sec   | 207 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 895 Mbits/sec   | 372 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 784 Mbits/sec   | 82.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 950 Mbits/sec   | 491 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 957 Mbits/sec   | 791 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.02 Gbits/sec  | 1.02 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 319 Mbits/sec   | 503 Mbits/sec
    Single Core     | 542
    Multi Core      | 1001
    Full Test       | https://browser.geekbench.com/v5/cpu/8264591
    edited June 2021
    #                     v2021-06-05                    #
    AES-NI     : ❌ Disabled
    RAM        : 908.2 MiB
    Swap       : 1024.0 MiB
    Disk       : 14.6 GiB
    Single Core     | 98
    Multi Core      | 282
    edited June 2021
    Raspberry Pi Zero, Connected via Wifi, 1.04$ per Month
    #                     v2021-06-05                    #
    Sat  5 Jun 11:51:01 BST 2021
    Processor  : ARM1176
    CPU cores  : 1 @ 1000.0000 MHz
    AES-NI     : ❌ Disabled
    RAM        : 431.9 MiB
    Swap       : 100.0 MiB
    Disk       : 14.6 GiB
    Read       | 1.55 MB/s      (388) | 6.14 MB/s       (96)
    Write      | 1.58 MB/s      (396) | 6.46 MB/s      (100)
    Total      | 3.14 MB/s      (784) | 12.60 MB/s     (196)
    Read       | 8.66 MB/s       (16) | 8.63 MB/s        (8)
    Write      | 9.47 MB/s       (18) | 9.65 MB/s        (9)
    Total      | 18.13 MB/s      (34) | 18.29 MB/s      (17)
    Clouvider       | London, UK (10G)          | 6.69 Mbits/sec  | 13.4 Mbits/sec
    Online.net      | Paris, FR (10G)           | 6.00 Mbits/sec  | 13.4 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 5.11 Mbits/sec  | 13.0 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 3.28 Mbits/sec  | 8.49 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 17.3 Mbits/sec  | 14.9 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 7.73 Mbits/sec  | 14.7 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 13.3 Mbits/sec  | 14.9 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 3.67 Mbits/sec  | 12.0 Mbits/sec
    Clouvider       | London, UK (10G)          | 6.70 Mbits/sec  | 12.9 Mbits/sec
    Online.net      | Paris, FR (10G)           | 5.40 Mbits/sec  | 12.8 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 5.44 Mbits/sec  | 13.1 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 11.8 Mbits/sec  | 14.5 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 8.18 Mbits/sec  | 14.3 Mbits/sec
    @Mason Geekbench won't work on Pi Zero.
    #                     v2021-06-05                    #
    Processor  : ARM1176
    AES-NI     : ❌ Disabled
    RAM        : 431.9 MiB
    Swap       : 100.0 MiB
    Disk       : 14.6 GiB
    decent IOPS. Class A microSD?
    Likely, ask @DataIdeas
    No idea how to write out which specific type it is.
    Ikoula Raspberry Pi4, 2.50€, 4GB, 1000Mbit full duplex v6 only (v4 routed via mesh)
    root@FRA1:~# curl -sL yabs.sh | bash
    root@FRA1:~# ip route add default via 10.0.251.1
    #                     v2021-06-05                    #
    Sat  5 Jun 10:52:18 UTC 2021
    Processor  : Cortex-A72
    CPU cores  : 4 @ 1500.0000 MHz
    AES-NI     : ❌ Disabled
    RAM        : 3.7 GiB
    Swap       : 0.0 KiB
    Disk       : 14.5 GiB
    Read       | 1.62 MB/s      (405) | 4.08 MB/s       (63)
    Write      | 1.64 MB/s      (411) | 4.36 MB/s       (68)
    Total      | 3.26 MB/s      (816) | 8.45 MB/s      (131)
    Read       | 2.00 MB/s        (3) | 3.10 MB/s        (3)
    Write      | 2.15 MB/s        (4) | 3.39 MB/s        (3)
    Total      | 4.16 MB/s        (7) | 6.50 MB/s        (6)
    Clouvider       | London, UK (10G)          | 143 Mbits/sec   | 110 Mbits/sec
    Online.net      | Paris, FR (10G)           | 151 Mbits/sec   | 132 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 161 Mbits/sec   | 162 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 100 Mbits/sec   | 10.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 134 Mbits/sec   | 77.8 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 123 Mbits/sec   | 51.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 114 Mbits/sec   | 64.7 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 63.3 Mbits/sec  | 43.2 Mbits/sec
    Clouvider       | London, UK (10G)          | 923 Mbits/sec   | 924 Mbits/sec
    Online.net      | Paris, FR (10G)           | 932 Mbits/sec   | 926 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 918 Mbits/sec   | 808 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 616 Mbits/sec   | 220 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 42.5 Mbits/sec  | 135 Mbits/sec
    Single Core     | 233
    Multi Core      | 678
    Full Test       | https://browser.geekbench.com/v5/cpu/8266791
    Ikoula Raspberry Pi 4 #2, 2.50€, 4GB, 1000Mbit full duplex
    root@FRA2:~# curl -sL yabs.sh | bash
    root@FRA2:~# ip route add default via 10.0.251.1
    #                     v2021-06-05                    #
    Sat Jun  5 10:59:57 UTC 2021
    AES-NI     : ❌ Disabled
    RAM        : 3.7 GiB
    Swap       : 0.0 KiB
    Disk       : 14.5 GiB
    Read       | 1.80 MB/s      (452) | 7.54 MB/s      (117)
    Write      | 1.83 MB/s      (458) | 7.93 MB/s      (124)
    Total      | 3.64 MB/s      (910) | 15.48 MB/s     (241)
    Read       | 10.23 MB/s      (19) | 10.16 MB/s       (9)
    Write      | 11.46 MB/s      (22) | 11.16 MB/s      (10)
    Total      | 21.70 MB/s      (41) | 21.32 MB/s      (19)
    Clouvider       | London, UK (10G)          | 148 Mbits/sec   | 130 Mbits/sec
    Online.net      | Paris, FR (10G)           | 146 Mbits/sec   | 104 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 151 Mbits/sec   | 141 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 117 Mbits/sec   | 10.5 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 134 Mbits/sec   | 65.7 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 130 Mbits/sec   | 52.3 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 114 Mbits/sec   | 43.6 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 65.5 Mbits/sec  | 32.6 Mbits/sec
    Clouvider       | London, UK (10G)          | 924 Mbits/sec   | 909 Mbits/sec
    Online.net      | Paris, FR (10G)           | 928 Mbits/sec   | 927 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 919 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 785 Mbits/sec   | 333 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 130 Mbits/sec   | 107 Mbits/sec
    Single Core     | 233
    Multi Core      | 668
    Full Test       | https://browser.geekbench.com/v5/cpu/8266852
  • @Neoon said:
    RAM        : 431.9 MiB
    Swap       : 100.0 MiB
    I think GB5 would need 1 GB of swap or something to work.
    gb runs on 1.5GB Ram as well
    racknerd
    root@cybertech:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-06-05                    #
    Sat Jun  5 20:12:28 +08 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 1 @ 2800.000 MHz
    RAM        : 1.4 GiB
    Swap       : 0.0 KiB
    Disk       : 20.0 GiB
    Read       | 57.65 MB/s   (14.4k) | 768.42 MB/s  (12.0k)
    Write      | 57.74 MB/s   (14.4k) | 772.46 MB/s  (12.0k)
    Total      | 115.39 MB/s  (28.8k) | 1.54 GB/s    (24.0k)
    Read       | 1.15 GB/s     (2.2k) | 1.09 GB/s     (1.0k)
    Write      | 1.21 GB/s     (2.3k) | 1.16 GB/s     (1.1k)
    Total      | 2.36 GB/s     (4.6k) | 2.26 GB/s     (2.2k)
    Clouvider       | London, UK (10G)          | 616 Mbits/sec   | 394 Mbits/sec
    Online.net      | Paris, FR (10G)           | 643 Mbits/sec   | 175 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 604 Mbits/sec   | busy
    Biznet          | Jakarta, Indonesia (1G)   | 579 Mbits/sec   | 179 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 735 Mbits/sec   | 246 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 788 Mbits/sec   | 276 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 840 Mbits/sec   | 743 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 625 Mbits/sec   | 174 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 2433
    Multi Core      | 2362
    Full Test       | https://browser.geekbench.com/v4/cpu/16209901
    Single Core     | 489
    Multi Core      | 477
    Full Test       | https://browser.geekbench.com/v5/cpu/8267663
    Yep, as @flips said, need a good amount of swap for it to actually run. It only completed on my Pi (which has 1G mem) after I added a swap partition.
    Maybe could put a warning in there if the Geekbench fails and low/no swap is detected and let the user know to try adding some.
    edited June 2021
    Um, this is from Oracle Cloud in Phoenix. I have to go through and set it up again and pay more attention. 😵 @Mason
    [opc@instance ~]$ curl -sL yabs.sh | bash
    #                     v2021-06-05                    #
    Sun Jun  6 02:55:19 GMT 2021
    Processor  :
    CPU cores  : 2
    NUMA node0 0,1 @  MHz
    RAM        : 10.6 GiB
    Swap       : 4.0 GiB
    Disk       : 50.0 GiB
    Read       | 6.40 MB/s     (1.6k) | 26.66 MB/s     (416)
    Write      | 6.40 MB/s     (1.6k) | 27.45 MB/s     (429)
    Total      | 12.80 MB/s    (3.2k) | 54.11 MB/s     (845)
    Read       | 24.18 MB/s      (47) | 23.85 MB/s      (23)
    Write      | 26.25 MB/s      (51) | 26.61 MB/s      (25)
    Total      | 50.44 MB/s      (98) | 50.46 MB/s      (48)
    Clouvider       | London, UK (10G)          | 583 Mbits/sec   | 903 Mbits/sec
    Online.net      | Paris, FR (10G)           | 666 Mbits/sec   | 140 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 568 Mbits/sec   | 833 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 534 Mbits/sec   | 56.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 958 Mbits/sec   | 936 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 968 Mbits/sec   | 944 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.02 Gbits/sec  | 1.01 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 504 Mbits/sec   | 321 Mbits/sec
    Single Core     | 856
    Multi Core      | 1696
    Full Test       | https://browser.geekbench.com/v5/cpu/8277030
    [opc@instance ~]$
    @Not_Oles said: Um, this is from Oracle Cloud in Phoenix. I have to go through and set it up again and pay more attention. 😵 @Mason
    Looks like some parts of the script aren't playing nice with your OS (Oracle Linux Server). I'll have to play around in Oracle Cloud and test it out a bit.
    Thanked by (2)Not_Oles cybertech
  • Previous benchmark here
    With wireguard connected to GCP so I don't have shite international network speed, ran inside a KVM (6 Core/16 GB RAM/100 GB HDD)
    #                     v2021-06-05                    #
    Mon 07 Jun 2021 09:53:43 AM UTC
    Processor  : Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
    CPU cores  : 6 @ 2599.996 MHz
    RAM        : 15.6 GiB
    Swap       : 4.0 GiB
    Disk       : 98.4 GiB
    Read       | 198.40 MB/s  (49.6k) | 1.98 GB/s    (30.9k)
    Write      | 198.93 MB/s  (49.7k) | 1.99 GB/s    (31.1k)
    Total      | 397.33 MB/s  (99.3k) | 3.97 GB/s    (62.1k)
    Read       | 2.29 GB/s     (4.4k) | 1.97 GB/s     (1.9k)
    Write      | 2.41 GB/s     (4.7k) | 2.10 GB/s     (2.0k)
    Total      | 4.70 GB/s     (9.1k) | 4.07 GB/s     (3.9k)
    Clouvider       | London, UK (10G)          | 451 Mbits/sec   | 90.1 Mbits/sec
    Online.net      | Paris, FR (10G)           | 437 Mbits/sec   | 257 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | busy
    Biznet          | Jakarta, Indonesia (1G)   | 734 Mbits/sec   | 264 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 509 Mbits/sec   | 152 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 528 Mbits/sec   | 138 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 606 Mbits/sec   | 134 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 70.2 Mbits/sec
    Single Core     | 625
    Multi Core      | 3383
    Full Test       | https://browser.geekbench.com/v5/cpu/8295592
  • vyasvyas OGSenpai
    edited June 2021
    Amidst all the HS drama, I thought of running a YABS on the NVME VPS . Here goes
    Edit : @cybertech this is the base plan.
    Wed Jun  9 08:42:15 UTC 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
    CPU cores  : 1 @ 2397.222 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 38.7 GiB
    Read       | 111.72 MB/s  (27.9k) | 715.09 MB/s  (11.1k)
    Write      | 112.01 MB/s  (28.0k) | 718.85 MB/s  (11.2k)
    Total      | 223.74 MB/s  (55.9k) | 1.43 GB/s    (22.4k)
    Read       | 1.30 GB/s     (2.5k) | 1.15 GB/s     (1.1k)
    Write      | 1.37 GB/s     (2.6k) | 1.22 GB/s     (1.1k)
    Total      | 2.68 GB/s     (5.2k) | 2.38 GB/s     (2.3k)
    Clouvider       | London, UK (10G)          | 827 Mbits/sec   | 223 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | busy
    WorldStream     | The Netherlands (10G)     | 842 Mbits/sec   | 281 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 642 Mbits/sec   | 107 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 675 Mbits/sec   | 160 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 701 Mbits/sec   | 174 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 753 Mbits/sec   | 213 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 667 Mbits/sec   | 169 Mbits/sec
    Single Core     | 603
    Multi Core      | 613
    Full Test       | https://browser.geekbench.com/v5/cpu/8326315
