Mate, with those specs, you make me feel sad about my PhP- Friends VPs :-)
Those are some nice numbers.
Well, the specs are fine, but i would choose Avoro or Netcup instead of them, a little better performance tho, same as peering. But yeah. Php-friends are awesome in overall!
@hanoi said:
OneProvider Storage VM 2TB Lisbon - PT
IP:185.113.143.xxx
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 58
Multi Core | 107
Full Test | https://browser.geekbench.com/v5/cpu/8476381
IP:185.113.143.xxx
Test | Value
Single Core | 58
Multi Core | 107
IP:185.113.143.xxx
Test | Value
Single Core | 58
Multi Core | 107
IP:185.113.143.xxx
Test | Value
Single Core | 58
Multi Core | 107
@cybertech Yes. If you want Ubuntu, click the checkbox for Ubuntu minimal. The GUI will raise an error flag, but also will -- unexpectedly -- expose a version option. Change the version from minimal to 20 and the error flag will go away. Maybe it's ungood UI that the Ubuntu version option is not visible until after the Ubuntu OS checkbox is clicked.
Hmm. I should go click each of the OS options to see if any interesting versions then appear.
A few days ago I did find and spin up Solaris. Friendly greetings from Mexico!
@11111jfkdd said:
VPSSLIM black friday 1.5 eur monthly ovz
Decent numbers for the price. Was it VPSSlim whose GB5 CPU figures were in 2 digits?
Idk. I have heard many bad things about them being oversold and stuff and was skeptical, but since it was so cheap I got it. Incredible uptime and performance good for the price, although not good disk speed (can't complain for 150gb of disk)
PinePhone 3GB running Mobian.
2.4GHz WiFi network. IPv4 is Verizon FiOS, Washington DC market. IPv6 is TunnelBroker Ashburn server.
Charger is connected.
@yoursunny said: PinePhone 3GB running Mobian.
does it have most things working? how's the fluidity? it's a pity the hardware is really dated. hope something newer comes up, at least Snapdragon or something
Virmach 512 MB "free" VPS.
not bad for a 6 4 month freebie, of course with time, this will turn into one busy neighbourhood!
Got this one just so that @cybertech could thank me - for adding one more BM to list collection :-)
Note: GB5 was not able to run- so posting GB4 results. Yes, formatting is whacky.
Sun 04 Jul 2021 11:10:51 AM BST
Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
CPU cores : 1 @ 2499.998 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 488.3 MiB
Swap : 256.0 MiB
Disk : 14.5 GiB
Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with fio Disk Speed Tests (Mixed R/W 50/50):
Read | 66.08 MB/s (16.5k) | 869.34 MB/s (13.5k)
Write | 66.22 MB/s (16.5k) | 873.92 MB/s (13.6k)
Total | 132.30 MB/s (33.0k) | 1.74 GB/s (27.2k)
Read | 1.19 GB/s (2.3k) | 1.36 GB/s (1.3k)
Write | 1.25 GB/s (2.4k) | 1.45 GB/s (1.4k)
Total | 2.45 GB/s (4.7k) | 2.82 GB/s (2.7k)
Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | London, UK (10G) | 1.62 Gbits/sec | 634 Mbits/sec
Performing IPv4 iperf3 send test to Online.nPerforming IPv4 iperf3 send test to Online.nPerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlineOnline.net | Paris, FR (10G) | 1.53 Gbits/sec | 757 Mbits/sec
Performing IPv4 iperf3 send test to WorldStrPerforming IPv4 iperf3 recv test from WorldSWorldStream | The Netherlands (10G) | 1.57 Gbits/sec | 523 Mbits/sec
Performing IPv4 iperf3 send test to Biznet (Performing IPv4 iperf3 send test to Biznet (Performing IPv4 iperf3 recv test from BiznetBiznet | Jakarta, Indonesia (1G) | 438 Mbits/sec | 11.0 Mbits/sec
Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | NYC, NY, US (10G) | 6.30 Gbits/sec | 1.38 Gbits/sec
Performing IPv4 iperf3 send test to VelocityPerforming IPv4 iperf3 recv test from VelociVelocity Online | Tallahassee, FL, US (10G) | 1.92 Gbits/sec | 1.48 Gbits/sec
Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | Los Angeles, CA, US (10G) | 2.00 Gbits/sec | 878 Mbits/sec
Performing IPv4 iperf3 send test to Iveloz TPerforming IPv4 iperf3 recv test from IvelozIveloz Telecom | Sao Paulo, BR (2G) | 366 Mbits/sec | 175 Mbits/sec
Running GB5 benchmark test... *cue elevator Geekbench 5 test failed. Run manually to determine cause.
Running GB4 benchmark test... *cue elevator Geekbench 4 Benchmark Test:
Test | Value
Single Core | 2029
Multi Core | 2062
Full Test | https://browser.geekbench.com/v4/cpu/16249161
not bad for a 6 month freebie, of course with time, this will turn into one busy neighbourhood!
> Basic System Information:
> AES-NI : ✔ Enabled
> RAM : 488.3 MiB
> Swap : 256.0 MiB
> Disk : 14.5 GiB
> iperf3 Network Speed Tests (IPv4):
> Test | Value
> Single Core | 2029
> Multi Core | 2062
haha. nice. I have one last service with virmach that I'm eagerly waiting to let expire. gotten tired of trying anything serious on it.
this was HS NVMe base plan?
Mines the 2vCPU , 50GB NVMe and it does a lovely full 5gbps.....while it lasts
Netcup
Avoro
late to the game, just got IPv6 assigned to hosthatch lax
IPv6 hall of fame
Php-Friends
@LetMeBeSad
blog | exploring visually |
avoro has best overall value for money
dedicatserver
EUR 3 monthly
30 NVMe + 50GB SSD networked storage
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jun 16 13:09:53 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz CPU cores : 2 @ 2599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 79.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 150.59 MB/s (37.6k) | 1.59 GB/s (24.9k) Write | 150.99 MB/s (37.7k) | 1.60 GB/s (25.0k) Total | 301.59 MB/s (75.3k) | 3.20 GB/s (50.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.27 GB/s (4.4k) | 2.29 GB/s (2.2k) Write | 2.39 GB/s (4.6k) | 2.44 GB/s (2.3k) Total | 4.67 GB/s (9.1k) | 4.73 GB/s (4.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 567 Mbits/sec | 550 Mbits/sec Online.net | Paris, FR (10G) | 566 Mbits/sec | 550 Mbits/sec WorldStream | The Netherlands (10G) | 566 Mbits/sec | 468 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 476 Mbits/sec | 247 Mbits/sec Clouvider | NYC, NY, US (10G) | 538 Mbits/sec | 228 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 519 Mbits/sec | 263 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 519 Mbits/sec | 217 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 489 Mbits/sec | 140 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3118 Multi Core | 5489 Full Test | https://browser.geekbench.com/v4/cpu/16225723 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 686 Multi Core | 1245 Full Test | https://browser.geekbench.com/v5/cpu/8429209I bench YABS 24/7/365 unless it's a leap year.
Netcup after a little tunning
. I was reaching up to 7 Gb/s on 1m block size.
OneProvider Storage VM 2TB Helsinki - FI
IP: 37.143.129.xxx
OneProvider Storage VM 2TB Oslo - NO
IP: 185.46.132.xxx
IP:185.113.143.xxx
Is that type of your VM?
https://dedicatserver.ro/en/cloud-vps-vds/
wow, they said
Internet - 100 Mbpscap but seem it is 500 MbpsWtf
True low end spirit bros
yes
Oracle Cloud instance in Phoenix
what OS is this on? Ubuntu?
lovely.
bigger the better oracle cloud free tier
Oracle Cloud Phoenix. Same instance as posted above at https://talk.lowendspirit.com/discussion/comment/66642/#Comment_66642
What happened to the iperf3 receive performance?
good port speed and uptime, although the disk is pretty slow. overall a good value, i will buy another if they do black friday similar offers
Dedipath $9.25/mo ovz 6gb (with a web server and sql running in the background)
includes 3 ipv4 in the price, although i have no use for the extras
vps9hostname is available. affbrrdoes it have most things working? how's the fluidity? it's a pity the hardware is really dated. hope something newer comes up, at least Snapdragon or something
Sun 04 Jul 2021 11:10:51 AM BST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU cores : 1 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 488.3 MiB Swap : 256.0 MiB Disk : 14.5 GiB Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with Running fio random mixed R+W disk test with fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 66.08 MB/s (16.5k) | 869.34 MB/s (13.5k) Write | 66.22 MB/s (16.5k) | 873.92 MB/s (13.6k) Total | 132.30 MB/s (33.0k) | 1.74 GB/s (27.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.19 GB/s (2.3k) | 1.36 GB/s (1.3k) Write | 1.25 GB/s (2.4k) | 1.45 GB/s (1.4k) Total | 2.45 GB/s (4.7k) | 2.82 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | London, UK (10G) | 1.62 Gbits/sec | 634 Mbits/sec Performing IPv4 iperf3 send test to Online.nPerforming IPv4 iperf3 send test to Online.nPerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlinePerforming IPv4 iperf3 recv test from OnlineOnline.net | Paris, FR (10G) | 1.53 Gbits/sec | 757 Mbits/sec Performing IPv4 iperf3 send test to WorldStrPerforming IPv4 iperf3 recv test from WorldSWorldStream | The Netherlands (10G) | 1.57 Gbits/sec | 523 Mbits/sec Performing IPv4 iperf3 send test to Biznet (Performing IPv4 iperf3 send test to Biznet (Performing IPv4 iperf3 recv test from BiznetBiznet | Jakarta, Indonesia (1G) | 438 Mbits/sec | 11.0 Mbits/sec Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | NYC, NY, US (10G) | 6.30 Gbits/sec | 1.38 Gbits/sec Performing IPv4 iperf3 send test to VelocityPerforming IPv4 iperf3 recv test from VelociVelocity Online | Tallahassee, FL, US (10G) | 1.92 Gbits/sec | 1.48 Gbits/sec Performing IPv4 iperf3 send test to ClouvidePerforming IPv4 iperf3 recv test from ClouviClouvider | Los Angeles, CA, US (10G) | 2.00 Gbits/sec | 878 Mbits/sec Performing IPv4 iperf3 send test to Iveloz TPerforming IPv4 iperf3 recv test from IvelozIveloz Telecom | Sao Paulo, BR (2G) | 366 Mbits/sec | 175 Mbits/sec Running GB5 benchmark test... *cue elevator Geekbench 5 test failed. Run manually to determine cause. ----- Running GB4 benchmark test... *cue elevator Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2029 Multi Core | 2062 Full Test | https://browser.geekbench.com/v4/cpu/16249161blog | exploring visually |
GB5 should run if you give it 1 GB of swap.
