Requesting Reviews for Hosting Provider fasthosts
edited June 2021 in Help
So i came across provider named fasthosts offering vps. Has anybody used it? Any review/advice is helpful.
https://www.fasthosts.co.uk/virtual-private-servers
  • vyasvyas OGSenpai
    Congratulations on your first post
  • Hi , i have done posts before but thanks.
    Thanked by (1)_MS_
  • _MS__MS_ OGSenpai
    edited June 2021
    Did not expect that :D :+1:
    I know that they were mainly a Shared Hosting provider. Remember, a VPS is not necessarily a VM, it could also be just a Container, check with them if they offer KVM as "Servers" or just OpenVZ and LXC. Ctrl+F can't find "KVM" on their VPS page.
  • vyasvyas OGSenpai
    In that case...
    Belated congratulations on your first post .
    @angstrom
  • mikhomikho AdministratorOG
    They do allow Windows as an alternative OS, that rules out openVZ and LXC.
    Thanked by (1)_MS_
  • I talked to their support and they replied that they have 500Mbps unmetered ports. As per support you can saturate 500Mbps fully and unlimited data. That sounds too good to be true. That's why asked for suggestion. Mainly i use buyvm and letbox. Planning to use fasthosts one for rclone transfers.
  • _MS__MS_ OGSenpai
    @mikho said: They do allow Windows as an alternative OS, that rules out openVZ and LXC.
    This makes the pricing look great.
    @agadmin said: That sounds too good to be true.
    Only one way to find out. Don't forget to leave a benchmark for the community :)
    Thanked by (1)mikho
