Connection issues inside vps
In a vps, when i log in...it says
Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
and when i do git pull it fails with message fatal: unable to access 'https://github.com/brand/repo/': gnutls_handshake() failed: Error in the pull function.
what could be the solution? many answers say updating git, libssls etc but none worked.
hoping to find a solution here.
thanks.
ofc updating won't work since the message writes:
Check your Internet connection or proxy settingsDid you check your internet connection?
do you need to use any kind of vpn/proxy from that vps to get to the outside world?
port 443 blocked?
does ping work?
Check your DNS settings on the VPS, are you able to ping google.com or similar?
For example,
ping github.comworks very finei didn't install ufw and it worked fine till today but may be server people enforced it,
running
sudo netstat -tulpn | grep :443shows some are running on openlitespeedand i tried disabling ufw, no result
added https with
sudo ufw allow httpsstill no result.what else could be the problem?
Also is there any way to test whether https working or not from terminal? is there any command like
pingfor testing https?ThemeForest Profile
Checkout
wgetorcurl.— Michael
curl github.comfinishes in a blinkcurl https://github.comtakes forever and throws errorcurl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443ThemeForest Profile
not sure....what to do 🤷
ThemeForest Profile
Check date and time of VPS
if its a date/time mismatch, the certificate gets rejected.
curl http://github.com is fine but https isn't.. Are you running a super ancient distro such that ca-certificate is obsolete?
Try reducing MTU. HTTPS packets are larger than HTTP and improper MTU could be doing it.
or similar. The 1200 bytes is just for testing, probably won't need to go that low in reality.
If your MTU is too high could cause issues retrieving from HTTPS sites because the packets are too big.
Edit: oops what tetech said, didn't see his post.
Can you please tell me how? https://askubuntu.com/a/998449 tried this but no luck
Ubuntu 20
HOLY SHIT!!!.... that did the job.
now vps is blazing fast in git pull etc.
ThemeForest Profile
Thanks to everyone for posting your replies, i am able to solve it without contacting host
it was working fine till yesterday so not sure what caused it but i am able to solve it easily thanks to you guys especially @tetech
ThemeForest Profile
