Looking for any cheapest VPS with any GPU
I'm lookign for the cheapest vps that has some kind of gpu passthrough or whatever it is, a cheap dedi also suffice but i'm not really sure if it works, weak or strong should be fine
Ram needs to be over 4GB otherwise nothing works
Budget is just over $20 and can be flexible though, would prefer monthly or hourly and through a prepaid or Paypal
I have been looking at Paperspace but they don't accept Paypal and prepaid due to Stripe policy
Any input is appreciated
Maybe ikoula? Although it starts at 30 EUR.
Good luck with your budget...
Paperspace doesn't really sound like 20 dollars a month... (unless you mean the free promo that is apparently time- and quantity-limited, then yes)
https://docs.paperspace.com/gradient/more/instance-types
The above doesn't exactly look like a VPS btw, so in case you don't really need one but instead "something" (you won't be using it 24/7) with a GPU, consider trying out www.shadow.tech (the cheapest GPU-enabled option that I'm aware of)
If you really do need a server, this is perhaps one of the cheapest (starting at ~3x your stated monthly budget): https://www.serverroom.net/dedicated/gpu/pricing/
Alternatively, perhaps one of the cheapest hourly options: https://vast.ai/ (starting at 15 cents per hour for non-interruptible instances)
Finally, maybe @lentro can make you a custom offer (although based on the pricing available on their website, 20 dollars is probably a long shot)
@deank
"The end is nigh" incoming...
If you are Ok with an intel GPU:
https://www.kimsufi.com/en/order/kimsufi.xml?reference=1804sk181
i3, 4GB RAM, 2TB, 100Mbps, Canada
Not sure if it's enabled by default, but maybe it is?
I've been summoned.
The end is dickly nigh.
RPIServers 4GB plan, $7.50/month.
It comes with a dedicated VideoCore VI GPU.
I built a GPU Accelerated Contour Detection on a similar GPU.
vps9hostname is available. affbrr@lentro
I'm in need of Windows... but thanks for your input
