KVM VPS Poland & Singapore | Unblocks Netflix, Amazon, Dazn etc | Extra RAM,SSD,bandwidth
Hello!
We bring to you our latest stock clearance deals valid until July end.
Unblock Netflix, Youtube, Amazon etc. see down.
Bonus you get 30% extra everything on any plan, any billing term.
includes extra RAM, CPU, Bandwidth, disk , IPv6 too
How to apply?
1. Place a new order ,pay invoice.
2. Either post your Order # OR Create a support ticket.
See all Configurations - KVM VPS Poland π΅π±
See all Configurations - KVM VPS Singapore πΈπ¬
(Select Annual for 1 month discount extra)
Example Plan - 1
KVM-2GB (Poland & Singapore)
2.6 GB RAM
1 CPU Core (65% dedicated, 100% burstable)
32.5 NVMe/SSD disk
1 x IPv4 + /64 IPv6
Monthly transfer - 5.2 TB @ 1Gbps in Poland | 1.3 TB @ 1Gbps in Singapore
USD $6 monthly - Order Link Poland | Order Link Singapore
Example Plan - 2
KVM-1GB (Poland & Singapore)
1.3 GB RAM
1 CPU Core (32.5% dedicated, 100% burstable)
20 GB NVMe/SSD disk
1 x IPv4 + /64 IPv6
Monthly transfer - 1.3 TB @ 1Gbps in Poland | 650 GB @ 1Gbps in Singapore
USD $3 per month - Order link Poland | Order link Singapore
Features
- All use NVMe/SSD disks in RAID 1
- Includes backup option in panel
- Recently implemented - Live migration capability at Poland - megligible maintenance downtime.
- Balanced CPU - RAM ratio on all nodes.
- All nodes are connected to 1 Gbps dedicated ports.
- All of these can unblock various Online Streaming services including Netflix, Youtube, Amazon Prime, Hotstar, Dazn etc. see details below.
Network & looking Glass:
Singapore - Rackscentral SG1
Looking Glass - http://sgp-b.lg.webhorizon.in/
Ping/Traceroute Test IPv4 - 45.129.228.80
Ping/Traceroute Test IPv6 - 2403:cfc0:1006:152e::1
Unblocks - HotStar, Netflix, DisneyPlus, HBO GO, Amazon Prime, Steam (Region: SG)
Poland - Mevspace DC1
Looking Glass - http://waw.lg.webhorizon.in/
Ping/Traceroute Test IPv4 - 41.216.186.10
Ping/Traceroute Test IPv6 - 2a03:cfc0:803f:0a8d::1
Unblocks - Dazn, Netflix, Youtube, Amazon Prime, Steam (Region: PLN)
Payments - Crypto, CC via Stripe, PayPal, etc.
Support available - via Helpdesk OR Telegram
Thanks!
WebHorizon
Order 60ff10bf0169d
Thank you, will post yabs later π
Order ID seems to be 2216 after i paid
All done,please reinstall OS.
btw. That was a steal deal!
has 1 more use left I guess.
https://webhorizon.net
KVM NAT plans are discontinued π§
The category no longer exists on the order form.
What is 30% extra IPv6?
Normally it's one /64 prefix, so 30% more address space would be:
Or, did you deploy IPv7.8?
Unable to push-up due to shoulder injury π£
2x the BGP Sessions? still zero BGP Sessions Poland
RouteIX Networks :: Dedicated Servers in Fremont, California :: AS211954
Optix Transit :: Free IPv6 Transit :: AS209870
Once the user depletes their existing /64 subnet, we assign them additional /80 or another /64 if needed.
okay, lowenddetectives got us.
we discontinued new orders for NAT KVM because some users won't understand the service is ipv6 primary...in the end NAT IPv4 gets blocked by GFW & we have paypal disputes. Also, such VMs cannot be live-migrated for maintenance the ip4 will change.
Neither Warsaw nor Singapore has good connection to China, so MJJs shouldn't be buying these in the first place.
You could reopen orders for IPv6-only service though: no IPv4 at all, only IPv6.
It's useful for websites behind Cloudflare.
Another possibility is allowing NAT IPv4 outbound but no inbound port/domain forwarding (not even SSH).
It would allow said websites to make outbound API calls to IPv4-only services such as Docker Hub.
On the other hand, the KVM cannot be used as VPN easily.
It is technically possible to perform live migration on NAT server:
thanks for the good advice! I'll consider it. maybe for smaller 512MB plans this will work.
π€ technically possible but not worth the extra setup as we'll use NAT only for smaller plans, larger than 1 GB plans with dedicated IP.
Our Live Status page is online: https://status.webhorizon.in/
Are you retiring NAT KVM for existing peeps?
Cloudron.io - Lovely self hosted management suite [aff]
HetrixTools - Highly recommended uptime monitor [aff]
nope. They continue their service as-is.
Out of stock?
Hi,
The KVM Plans sold out in Singapore.
I have added some stock for VZ VPS Singapore
Thse are based on ovz virtualization.
Will KVM Singapore restock?
Hey, normal KVM plans in Singapore will be available by 15th next month.
We still have this custom 32 GB Slice from last sale, location is PNAP SG. (test IP 131.153.51.122)
July Special - Singapore - KVM
3 x Dedicated CPU Core(s) E-2776G
32GB DDR4 ECC RAM
120GB NVMe/SSD disk
1 x dedicated IPv4 + /64 IPv6
1.5 TB transfer @ 1Gbps per month
Location - Singapore
Order Link
@Abdullah
This Singapore vps can't unblock Netflix now, only can watch Netflix's homemade
Can you fix it?
Thank you
Hi,
Please create a ticket, we'll check the IP
