vServer.site
Hi guys,
I found vServer.site's client area hard to access. Every link I clicked on redirects me to the login page before loading the actual page I am accessing.
Is it just me or?
  • TheDPTheDP OGSenpai
    Looks to be all good from here.
  • Sounds like an issue with session cookies, make sure your browser is accepting them for their site, or try clearing your cache, if you haven't already.
  • No issues this side also
  • THIS is JUST the beginning
  • @恐怖原 said: vServer.site
    Maybe the account has been closed.
    Thanked by (1)chimichurri
    Most likely this... however I did not explicitly not accepting cookies from the site. There is a cookie notice when I entered the main site but not the client area?
    Also realized that Nexusbyte's client area is having the same problem. Also I have not explicitly disabled cookies from the site as well.
    maybe some antivirus/anti-malware/anti-whatever software playing tricks on you then?
  • Switching your browser to "incognito browsing mode" may solve the problem.
    (In such a case, the error is often caused by extensions like adblock)
    I started incognito mode on Chrome and still facing the same issue...?
    @terrorgen said: I started incognito mode on Chrome and still facing the same issue...?
    Perhaps consider taking a look inside the Chrome Development Tools CTRL-Shift-I and see what might be learned there?
  • Does it happen with other browsers as well? No issues here. I'm on Firefox.
