Dedicated Core VPS
I'm looking for a VPS with a dedicated core or two to perform some video encoding. 50-75GB of storage would also be needed.
Not exactly sure what to budget, so I'll leave that open for now.
I don't really want to spend $50-75 per month, which is why I'm not asking about dedicated servers.
Any suggestions?
https://talk.lowendspirit.com/discussion/3385/unbelievable-vps-offers-from-1-year-we-dont-need-black-friday-for-great-deals#latest
Heya, would these interest you? https://my.zadeservers.net/cart.php?gid=14. The cores are 50% dedicated (for ex., you can use upto 200% CPU consistently on a 4vCore plan).
I'd recommend taking a look at GPC from Genesis Hosting: https://genesishosting.com/genesis_public_cloud.html
Resources on demand, so you can terminate instances as needed once encoding is done and save quite a bit on already-affordable prices.
Performance, support has basically been flawless, and from what I hear, Eric's an awesome guy.
Interesting. I'll have to take a look. Internet Egress / Bandwidth is usually what kills the deal with these cloud providers, so hopefully it's not like 9 cents per GB like AWS, Azure, Google, etc.
@SagnikS - Thanks! I look into that too. I'd have to figure out how to limit CPU usage to 50%.
They're 0.005/GB, basically a non issue unless you are pushing tens of TB.
Nope, 2-3TB, so not too expensive at $10-15 per month. Thanks!
We can cap it on our side too if you want to fully utilize it 24x7. If you'd like to test out a trial, feel free to shoot me a PM.
Php Friends could be an option? I have one from bf 2019- can check they allow xfer if interested .
Performance has been as good as it gets
2c/6G/75Gssd
No cap on BW IIRC intel not epyc but around 22 eur/6 mos
blog | exploring visually |
A question others already asked: are you planning to use it 24/7 for the whole month? LunaNode's compute-optimized instances have dedicated cores starting at $20/month, billed hourly. They have a good "shelving" process where you can deallocate a VPS by API (and not get billed for it during that time) if you're not running 24/7. BW allowance of several TB included then $0.003/GB over that.
Since bandwidth nor port speed was not mentioned, why not just get a budget dedicated server like kimsufi or hetzner auction, or servdiscount dedicated servers?
wWw.AlbaHost.Net .AL domains, Dedicated Servers, VPS/VDS and Hosting Services. Geo located in Albania.
What is the allowed monthly bandwidth?
PM'ing you a screenshot from the plan - I do now know German that well- if you can get help in translation- that should help!
First and foremost, not 50-75 dollars OK, so what is your budget then? (Also, +1 to 'hourly billing or not?')
Hmmmm... is this really a dedicated core VPS? I have to say, at this price point, I'm rather skeptical...
Anyway, a couple of Ideas from me, up to some 2534 euros / mo. - each of the following has dedicated cores (or at least their support confirmed that they do not limit CPU usage - it is VPS after all so you might not be getting a full HW thread...), sorted from the cheapest:
Maybe give a shoutout to @Advin
netcup, buyvm, php-friends, prepaid-hoster
