Buy 1 get 1 VPS Free (KVM LA and NY) | Free BLESTA and DA | KVM & OpenVZ 7 | RAID 10 SSD | LA and NY
Los Angeles (PSYCHZ - LA1 and INTERNAP - LA2) (KVM and OpenVZ 7)
New York (INTERNAP) (Only KVM)
Server Location: Los Angeles (2 Locations in LA) and New York
Test IPv4 LA1: 103.114.160.9
Test IPv6 LA1: 2402:d0c0:0:2::2
Test IPv4 LA2: 185.255.131.10
Test IPv6 LA2: 2402:d0c0:2:12a::3c26
Test IPv4 NY: 91.189.187.10
Test IPv6 NY: 2402:d0c0:3:2::9423
Looking Glass LA - https://lg.hosteons.com (This is looking glass for our psychz location)
Looking Glass NY - http://lg.ny.hosteons.com
Server Status / Uptime: https://status.hosteons.com
For FREE Blesta License NO coupon code is required just submit a ticket after placing order we will activate a License for you.
“DA” - This gives you free Direct Admin Control panel, applicable on KVM VPS 2 - VPS 7 packages in both locations LA as well as NY. OVZ 2 - OVZ 7 Packages can also use this coupon to get free Direct Admin Panel
“LET20” - This coupon gives 20% discount on all billing cycles (Annual billing cycle gives you additional 25% discount) (applicable on KVM VPS1 - VPS 7 and OpenVZ OVZ1 - OVZ7 VPS packages only - https://hosteons.com/vps.php)
“DOUBLERAM” - This coupon will give you DOUBLE RAM, after placing order using this coupon code just submit a support ticket to DOUBLE your VPS RAM)
“DOUBLEDISK” - This coupon will give you DOUBLE SSD Disk Space, after placing order using this coupon code just submit a support ticket to DOUBLE your VPS Disk Space (SSD RAID 10)
"UPGRADE" - Use this coupon to get a free VPS Package upgrade e.g. if you ordered VPS 1 with 512 MB you can ask for free upgrade to Package VPS 2 with 1024 MB RAM and 10 G Disk space, same applies to all other packages, you basically get free upgrade to next higher VPS Package, once you use this coupon code and received your VPS Please submit a support ticket to get this upgrade. (This offer does not applies to Custom VPS and 256 MB RAM VPS, it can be used for any other VPS Packages and it's applicable only for new orders) This is a lifetime coupon/upgrade.
| DOUBLERAM | DOUBLEDISK | UPGRADE - These coupons or upgrades are recurring
Buy 1 Get 1 VPS Free offer (We have limited stock for this offer)
We are offering VPS bundle Package for our KVM VPS in LA and NY, you just order a KVM VPS using following links (only monthly billing cycle and this package or price is recurring), in this bundle you order a VPS in LA and then in the same order form order VPS in NY and you will be charged just for 1 VPS, please note if you cancel one VPS both VPS gets cancelled and it cannot be clubbed with any other offer or promos and only applicable on monthly billing cycles:
KVM VPS 1 - https://my.hosteons.com/cart.php?a=add&bid=2
KVM VPS 2 - https://my.hosteons.com/cart.php?a=add&bid=4
KVM VPS 3 - https://my.hosteons.com/cart.php?a=add&bid=5
KVM VPS 4 - https://my.hosteons.com/cart.php?a=add&bid=6
KVM VPS 5 - https://my.hosteons.com/cart.php?a=add&bid=7
KVM VPS 6 - https://my.hosteons.com/cart.php?a=add&bid=8
KVM VPS 7 - https://my.hosteons.com/cart.php?a=add&bid=9
Our KVM VPS Package specifications are available at https://hosteons.com/vps.php
Our OpenVZ 7 Packages are as under: (for FUSE and DOCKER please submit a support ticket after placing order we will enable it)
OVZ256MB ($12/year - No coupon codes are applicable on this package)
vCPU Core: 0.5 (Half CPU core)
RAM: 256 MB
Disk Space: 5 GB SSD
Bandwidth: Unmetered
OS: Linux
IPv4: 1 (Additional IPV4 available for $1 per IP per month)
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order Now from - https://my.hosteons.com/cart.php?a=add&pid=47
OVZ512 MB ($18/year - No coupon codes are applicable on this package)
vCPU Core: 1
RAM: 512 MB
Disk Space: 10 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order Now from - https://my.hosteons.com/cart.php?a=add&pid=45
OVZ1 ($2.4/mo use coupon LET20 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
vCPU Core: 1
RAM: 1 GB
Disk Space: 30 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order Now from - https://my.hosteons.com/cart.php?a=add&pid=38
OVZ2 ($4.8/mo use coupon LET20 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
vCPU Core: 2
RAM: 2 GB
Disk Space: 50 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order Now from - https://my.hosteons.com/cart.php?a=add&pid=39
We have many more OpenVZ 7 based VPS packages check them out at https://my.hosteons.com/cart.php?gid=12
Our KVM VPS Packages are as under:
512 MB VPS ($2.4/mo use coupon LET0 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
CPU Core: 1
RAM:512 Mb
Disk Space: 5 Gb SSD
OS: Linux / FreeBSD*
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order in LA: https://my.hosteons.com/cart.php?a=add&pid=1
Order in NY: https://my.hosteons.com/cart.php?a=add&pid=50
1GB VPS ($3.2/mo use coupon LET20 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
CPU Core: 1
RAM: 1GB
Disk Space: 10 Gb SSD
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order in LA: https://my.hosteons.com/cart.php?a=add&pid=2
Order in NY: https://my.hosteons.com/cart.php?a=add&pid=51
1.5GB VPS ($4/mo use coupon LET20 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
CPU Core: 1
RAM: 1.5Gb
Disk Space: 15 Gb SSD
OS: Linux / Windows / FreeBSD*
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order in LA: https://my.hosteons.com/cart.php?a=add&pid=3
Order in NY: https://my.hosteons.com/cart.php?a=add&pid=52
2GB VPS ($5.6/mo use coupon LEt20 or use coupon "UPGRADE" to get upgraded to our next VPS Package)
CPU Core: 1
RAM: 2Gb
Disk Space: 20 Gb SSD
IPv6: /64
RDNS: Yes
Control Panel: Yes
Order in LA: https://my.hosteons.com/cart.php?a=add&pid=4
Order in NY: https://my.hosteons.com/cart.php?a=add&pid=53
We have more KVM VPS Packages they are available at https://hosteons.com/vps.php
**CUSTOM VPS: **(You can Design your own VPS Package, select as much RAM, CPU Core, IP, Disk Space you want)
You can order custom vps from - https://my.hosteons.com/cart.php?a=add&pid=35
OpenVZ 7 Based VPS Pool Also available - check out https://hosteons.com/vps.php
IRC is allowed.
Private/Personal VPN/Proxy allowed, no public Proxies please.Even no spamming or any kind of abusive or illegal activities are allowed on our Network.
Some of our VPS packages offers Linux and some of them offers Linux as well as Windows OS depending upon your VPS Package.
We accept all popular modes of payments like:
1) Credit Cards (Stripe)
2) PayPal
3) AliPay
4) Union Pay
5) BitCoin
6) Web Money
7) QIWI
8) Yandex Money
9) Perfect Money
10) Bank Transfer
If any queries please submit a ticket from our website https://hosteons.com
Affiliates are also welcome, we offer flat 20% affiliate commission to all our affiliates.
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
Nice offers! With DA is a very nice bonus!
