Errata:
Advertised as 100Mbit unmetered... not sure why I got 1Gbit speeds, but I'm not complaining.
SSD is a SanDisk SSD i110 32GB.
CPU clock speed advertised as 1.1Ghz (dynamic frequency scaling enabled).
Biznet (Indonesia) iperf location (temporarily?) removed from network test. Seems to be down 99% of the time, so it's pretty much useless besides making the script take longer to run due to all the timeouts (each connection seems to hang, rather than getting a connection refused message back).
Maybe the Infosystems (Uzbekistan) location instead, but that isn't really APAC anymore. The Vetta Online (New Zealand) location would probably be good, but seems to be down as well and would rather not swap out a flaky location for a different flaky location.... Perhaps a LE* provider with lots of bandwidth in APAC (is that even a thing?) would be willing to donate an APAC location for the cause.
how much do u think is 'lots of bandwidth' in APAC ?
Heh... that's a great question that I unfortunately do not have the answer for. I honestly have no idea how much a single iperf location (that the script uses) goes through in bandwidth per month and any guess I make will likely be way off. I think this is the issue with the Biznet server -- perhaps the constant iperf activity (thanks to YABS) is eating through all their bandwidth and taking them offline until the quota restarts.
I'd be down for doing a trial run with a new APAC server where I'll add it to the script, have the provider monitor to see if the bandwidth usage is acceptable, and then either keep it moving forward or strike off the list if it proves to be too much.
UPDATE: Trialing a new APAC location sponsored by WebHorizon in Singapore (IPv4 + IPv6)
Location will undergo testing for the next couple weeks to make sure the bandwidth implications aren't too heavy. As long as everything is good from WebHorizon's perspective, we'll be keeping the location on permanently. Big thanks to @Abdullah!
hetzner cloud cx21 with 130gb storage volume attached
Yep
Wanted to run a BM on PHP-Friends VPS before truning it off, instead hit
on my Macbook Pro late 2012 (w/ SSD upgrade to 480 GB). Not bad for a @ 10 year old laptop. Network I need to look into.
So here goes...
Squats are the new Push-ups
... and here's the PHP Friends Machine. Older BM from Dec 2019 can be found on my blog here .
Primcast "M701" Dedicated Server
Errata:
SoYouStart FlashSale Dedi in Limburg (Germany), running ~900GiB raid10 + 4TiB in ZFS raidz (ARC limited to 4GB though)
Stromonic Mumbai
they changed their CPU policies and much better now.
JustHost.ru - DataLine (Tier-3, Moscow)
https://dttech.net - Personal Site.
How did you manage this?
Mine still has 60% packetloss
I just signed up and received it, but my ping with it is very stable and no packet loss.
what the price in usd?
With configuration parameters: 1 vCPU - 1GB Ram - 20GB NVMe Disk - 200 Mbps, my price is 3.66usd with 20% off code on LET
Don't really see any good alternatives -> https://iperf.fr/iperf-servers.php
how much do u think is 'lots of bandwidth' in APAC ?![:p :p](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/tongue.png)
https://webhorizon.net
I'd be down for doing a trial run with a new APAC server where I'll add it to the script, have the provider monitor to see if the bandwidth usage is acceptable, and then either keep it moving forward or strike off the list if it proves to be too much.![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
Vultr HF Mexico
https://browser.geekbench.com/v5/cpu/10316332
Ooh, nice. Do you happen to live in MX? How's the local peering/connectivity?
Location will undergo testing for the next couple weeks to make sure the bandwidth implications aren't too heavy. As long as everything is good from WebHorizon's perspective, we'll be keeping the location on permanently. Big thanks to @Abdullah!![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
(test from NYC)
testing new SG iperf
YABS from Singapore VPS, IPv6 connectivity using HE TunnelBroker
I do not, but maybe @Not_Oles
Racknerd XMAS 3 GB KVM
Contact me at: +1 (509) 606-3569 or [email protected]
Would you please tell me from what provider?
fibera.io with new iperfs
It is GreenCloudVPS special Singapore independence day
which provider?
@11111jfkdd Hetzner
im assuming you bought the 10gbit upgrade?
